Hi all devoted ABB programmers,
Here is some code I wrote some years ago, posting it here for you to use, learn some programming. There are no warranties express or implied, user assumes all risks. Here goes:
MODULE LEERULZ
! This module contains two routines, rEnter and rExit which are
! intended to be universal handshake routines for requesting
! entry from the cell controller to enter an area, fixture or
! robot interference zone. When called, the user must pass in
! the parameters and switches unique to the user's installation.
! I.E., Digital inputs and digital outputs from your IO map, your
! tool and workobjects, if used. Nothing is hard-coded, so there
! is no need to rewrite these routines for your particular
! project. Both routines have Backward handlers so the user will
! be able to step backwards through the procedure call. The robot
! will move back to where it came from using the parameter passed
! which should be the parameter robtarget or jointtarget from which
! it came when requesting entry or exit. Then It will set or reset
! the digital output for clear as appropriate to enter or exit.
! pass in the parameter for the path interpolation used, linear, joint
! or MoveAbsJ. Or, the default will be joint interpolation.
! Example procedure call:
! rEnter "Station 1", doSta1EntRequest, diSta1ClearEnter1, doSta1InFixture, tGripper\WObj:=wobjStation1\swMoveJoint\pPreviouspoint:=p10;
PROC rEnter(
string area,
VAR signaldo request,
VAR signaldi signal,
VAR signaldo notclear,
PERS tooldata tool,
\PERS wobjdata WObj
\switch swMoveAbs
|switch swMoveLin
|switch swMoveJoint
\robtarget pPreviouspoint
|jointtarget jposPrevious)
VAR num nDummy;
VAR bool bTimeFlag;
VAR errnum erBreakFlag;
CONST string stFixClear:="Clear signal has been received, ";
IF (NOT Present(pPreviouspoint)) AND (NOT Present(jposPrevious)) THEN
TPErase;
TPWrite "Neither a robtarget nor a jointtarget were provided!!!";
TPWrite "Please remedy this from where this";
TPWrite "procedure was called.";
TPWrite "Backwards execution will NOT be possible!!!";
ENDIF
IF (Present(jposPrevious)) AND (NOT Present(swMoveAbs)) THEN
TPErase;
TPWrite "The optional switch for MoveAbsJ was not provided";
TPWrite " but a jointtarget was!!!";
ENDIF
Set request;
WaitUntil signal=1\MaxTime:=2\TimeFlag:=bTimeFlag;
IF bTimeFlag AND OpMode()=OP_MAN_PROG THEN
TPWrite "Waiting for Clear signal, ";
TPReadFK nDummy,ArgName(signal),"","",""," ",""\DIBreak:=signal\BreakFlag:=erBreakFlag;
ELSE
TPWrite ArgName(signal);
WaitDI signal,1;
ENDIF
TPWrite stFixClear;
Reset notclear;
Reset request;
BACKWARD
TPErase;
TPWrite "Please remedy this from where this procedure";
TPWrite "was called.";
ENDIF
IF Present(swMoveAbs) THEN
MoveAbsJ jposPrevious,v500,fine,Tool\WObj?WObj;
ELSEIF Present(swMoveLin) THEN
MoveL pPreviouspoint,v500,fine,Tool\WObj?WObj;
ELSE
MoveJ pPreviouspoint,v500,fine,Tool\WObj?WObj;
ENDIF
TPWrite "Robot clearing " + area;
Set notclear;
RETURN;
ENDPROC
PROC rExit(
string area,
PERS tooldata tool,
\PERS wobjdata WObj
\switch swMoveAbs
|switch swMoveLin
|switch swMoveJoint
VAR num nDummy;
VAR bool bTimeFlag;
CONST string stExiting:="Robot exiting ";
CONST string stReturning:="Robot Returning ";
TPErase;
ENDIF
TPErase;
ENDIF
Set request;
ELSE
WaitDI signal,1;
ENDIF
TPWrite stExiting+area;
! The VAR signaldo notclear is not set here
! because some motion is necessary to get the
! robot actually clear. If it were set here
! then the robot is not clear because no Motion
! has occurred yet.
Reset request;
BACKWARD
Reset notclear;
ELSE
ENDIF
TPWrite stReturning+area;
RETURN;
ENDPROC
ENDMODULE
