How to send Digital I/O from KRC2 controller to Arduino?
  • vikovarga
  • October 29, 2017 at 2:17 PM
  • vikovarga
    Hi everyone,
    I have designed a 3D printed gripper to KUKA KR5 robotic arm. I control the robot with teach pendant but I have to control the gripper with Arduino and bluetooth module using an android application because I cannot connect the KRC2 controller with my Arduino.
    My plan would be to send a Digital 1 signal from KRC2 to the Arduino. When it happenes the gripper would close. If a Digital 0 appears the gripper would open. It is my a senior project at my university but since I am a beginner in robot programming I stucked at this point.
    I tried to write a program code (please find it attached) and I wired X11 91th plug. Originally there was one more line between line 8 and 9 which was a WAIT 5s command but it's not on the picture. Then I monitorized with Arduino if Digital 0 changes to Digital 1 but nothing happened.
    Thanking you in advance for your time and assistance.
    Images
      • 188.06 kB
      • 618 × 349
      • 92
      • 206.37 kB
      • 350 × 619
      • 71
    Files
    Webp.net-resizeimage.jpg_thumb 20.18 kB – 158 Downloads Webp.net-resizeimage (2).jpg_thumb 29.78 kB – 158 Downloads
    panic mode
    1,293
    13,122
    • October 29, 2017 at 3:58 PM
    X11 interface is safety interface, has nothing to do with robot I/O (it is not influenced by your program) and functionality f each circuit is fixed.
    If you want to use robot I/O you need to install and configure I/O modules (devicenet for example) as described many times. you can check IOSYS.INI to see if any drivers are enabled and how I/O is mapped. Alternatively, you can try to use serial port.
    Arduino I/O are not directly compatible with industrial I/O. Industrial I/O are using 24V signals so some conditioning is required. Details will depend if you need isolation or not, definitely need to match the level, response time is also different.
  • irobot
    271
    • October 30, 2017 at 1:57 AM
    on the KRC2, you may chose the RS232 interface with Arduino
    KUKA Conntroller : _________<br />KSS Software : ____________ <br />Robot Model: _____________
  • vikovarga
    • October 30, 2017 at 10:40 AM
    Thank you for the answer. Could you tell me please how to communicate via Serial port? What program commands should I use? How to set up desired ports? How can I send any signals which could be monitorized with digitalRead command on Arduino?
    SkyeFire
    1,059
    9,450
    • October 30, 2017 at 2:37 PM
    Using the forum's Search function would be a good start.
    https://www.robot-forum.com/robotforum/man…ss-version-5-2/
    And as was already stated, you can't use DigitalRead with the serial port, you would have to use the Serial Library. And, even thought it's already been stated: DO NOT CONNECT THE ARDUINO DIRECTLY TO THE ROBOT. Even for the RS232 port, the voltages are not compatible. You will need a voltage adapter or circuit.
  • gigante
    15
    • October 30, 2017 at 10:29 PM
    We have used Arduino to control a stepper driven extruder with our KR6. However, we did it through a Beckhoff I/O. We used an EK1100 coupler and an EL2809 output module. The output signal from the controller closed a dry-contact relay. This triggered the Arduino and kept the voltages isolated. It's not a KRC2, but the principal is the same. Latency was not really an issue for our project.
    Edited once, last by gigante (October 30, 2017 at 10:45 PM).
