Trouble with UR3e and ProfiNet communication
  • Hello together,
    in the near future I have to programm an UR3e that will be controlled by a Beckhoff PLC via ProfiNet.
    I read the ProfiNet-Documentation and implemented the communication between the Robot and PLC.
    Actually everything is running - means it is possible to read/write all the Process Data on the PLC.
    On the Robot I wrote a small default program for testing and configured the Signals for Remote Control as follow:
    GP_bool_in[0] => Start
    GP_bool_in[1] => Stop
    GP_bool_in[2] => Pause
    GP_bool_in[3] => Freedrive
    GP_bool_in[4] => Auto start the default program in the Run Tab
    GP_bool_in[5] => Auto brake releas the Robot
    GP_bool_out[0] => Low when Program is not running
    GP_bool_out[1] => High when Program is not running
    GP_bool_out[2] => High when Program is running
    From the Process Data the PLC can read the State of the Robot:
    0 = Disconnected
    1 = Confirm_safety
    2 = Booting
    3 = Power_off
    4 = Power_on
    5 = Idle
    6 = Backdrive
    7 = Running
    And some other Flags:
    AOM = Analog output mask
    AOT = Analog output types
    ES = Is emergency stopped
    FT = Is fault
    NO = Is normal mode
    PB = Is power button pressed
    PR = Is program running
    PS = Is protective stopped
    PW = Is power on
    RC = Is recovery mode
    RD = Is reduced mode
    RES = Is robot emergency stopped
    SES = Is system emergency stopped
    SS = Is safeguard stopped
    SSM = Speed slider fraction mask
    ST = Is stopped due to safety
    TAIT = Tool analog input types
    TB = Is teach button pressed
    TDI = Tool digital inputs
    TDO = Tool digital outputs
    TDOM = Tool digital output mask
    VL=Is violation
    Now, my Question. How looks the Handshaking of the Input/Output-Signals to start the Robot remotely in a very reliable way and without using of the Dashboard-Server?
    I have problems to start the robot after turning on the controller. The default programm doesn't start everytime - but sometimes. I think there is a timing issue...:hmmm:
    In the past I programmed a lot of Applications with ABB, Kawasaki or KUKA an I had diagrams like that:
    7079-pasted-from-clipboard-png
    Is there something similar for the UR?
    Thanks in advanced and best regards...:hi-bye:
