I need some expert advice here!
I'm setting up Condition Monitor to work in my favor of preventing our operators from resetting collisions. How I want it to work is: I setup Collision Guard to trigger DO99 on once a collision occurs. Once the WHEN statement sees DO99 is on, it calls the Recovery to trigger DO100 on. In order for the fault to reset, DO100 needs to be off. Our technicians have to manually log in to turn on or off any I/O's. I had an easier method by running the same logic in BG but most of our software is R-30iA, which you cannot run UALM's in. The pictures I have attached are in R-30iB+ software.
I believe I have setup everything correct but still continue to receive a INTP-274 SYS_MON2 CH program error. Would anyone have some insight to provide here? $TTP_MON. $global_mt value has been changed to 2 under controlled start. Group mask, sub type and logic appears to be correct in my mind. What am I over looking here?
