Hi
I wonder how can i set tool X exactly perpendicularly to base? is there any good and easy to use method?
How to set tool X exactly perpendicularly to base?
Dzonzi -
May 31, 2019 at 11:20 PM -
select tool and base
then send orientation values to something square (ABC values are multiples of 90deg) -
Perpendicular to which axes of the Base?
For example, if you want to put the X+ vector of the Tool parallel to the Base Z+ vector (and, hence, perpendicular to the Base XY plane), an ABC set of 0,-90,0 should do it. To put Tool X antiparallel to Base Z (that is, Tool X- aligned with Base Z+), 0,+90,0 should do it.
Perpendicular to which axes of the Base?For example, if you want to put the X+ vector of the Tool parallel to the Base Z+ vector (and, hence, perpendicular to the Base XY plane), an ABC set of 0,-90,0 should do it.
That one Thanks.
