I am working on a :
- KR500-2-MT with KRC2 ed2005 / KSS 5.6
- a linear unit (E1)
- a simple turntable (E2)
Today I successfully remastered A1-A6 and E1 doing the EMT mastering procedure. Unfortunately, it does not work with the turntable : the mastering gauge passes through the V-notch correctly, the green leds go on/off correctly and in correct order but the process does not stop has it should just after passing the bottom of the V-notch. Unless, it goes on until the HMI says that the limit for mastering has been reached.
I have no ideas why I encounter this problem and how It could be solved. The notch looks fine. The EMT is working fine on the others axis. Any help/tips would be appreciate.
