Hi All, Apologies for poor info. New to forum. Will research some stuff on camera integration to kuka robot first and then get back with some relevant questions.
Want to use Kuka with camera to align spiral rod in gripper with tcp. rod may not always be straight and need to insert rod tip into tube.
Kuka used with camera to align tcp
Francisofarrell -
January 12, 2019 at 9:58 PM -
Hi Francis O'farrell,
I read your post more than two times but could not understand it. You may read the pinned post "READ FIRST", give details, mention your goal(s) precisely and what you have tried (or understood). These give better understanding to those who can provide some clues. -
Want to use Kuka with camera to align spiral rod in gripper with tcp. rod may not always be straight and need to insert rod tip into tube.How many degrees of freedom do you need to measure this "rod" in? To what degree of precision? How "spiral" is this rod? Can you control lighting, background? What is the critical point on the rod, and how is it defined -- how would the vision system identify it?
