Hallo..
The idea is: I want to divide the movement between 2 Points into number of steps (3 steps for example).. So I say
S=0 ; S: is a variable which has 0 when robot at StartPoint and 1 when robot at EndPoint
NextPoint= StartPoint+S(EndPoint-StartPoint)
The problem is when using For Loop, the program make only first update for the moving point then it doesn't move (During all For loop steps, the program stays at line 69 then when loop ends it completes normally)
I made the movement only in X just to understand what is going on..
program is attached...
Need your support to understand why the program doesn't update the value of MovingPoint.X for all FOR loop
Program is attached..
Thanx
