:LS file or .TXT File to modify as .TP
  • ravitejagali
  • September 7, 2018 at 6:36 AM
  • ravitejagali
    143
    Is there a way to convert .Ls file to .TP file without using external softwares like robguide or other.
    I send program to controller using ftp, batch commands which takes programm from other directory and make automatically. all robots are equipped with ascii uploader s/w package.
    I get .TP Programm with some Name, this Name i Need to Change it to CALL:Programm Name and sent it to Robot using ftp Batch program.
    Edited once, last by rAviteja_g (September 7, 2018 at 9:29 AM).
  • Nation
    Typical Robot Error
    529
    1,910
    • September 7, 2018 at 2:48 PM
    I am having trouble following what you are trying to do. Do want the robot to indirectly call the program you load?
  • Racermike123
    13
    901
    • September 8, 2018 at 6:18 PM
    Depending on what model you have you can load an LS file. The problem I see you having is calling a program that doesn't exist because you don't have a name for it.
  • ravitejagali
    143
    • September 10, 2018 at 9:31 AM
    Hallo Nation, Racermike123,
    This is how it goes, The robot programm(.TP programm), is placed in serever. And throuh barcode scanner I get path, After getting path I go to path and get robot .TP program and through ftp & batch programm I send this programm to robot.
    Now the problem is, the progrm name is not same every time_ for each work piece diffrent name, so that the operator knows it is correct program, but i call run program with same name_ to this process i need to change name.
    Controller side settings are all okay, Racermike123 The client access level is kept to 8 that means it is in installation. There is no problem with with level i think.
    My try: I tried to send normal .tp programm from local (My Pc) to remote(Robot), it worked out. And the same programm i changed name and tried to send, it got worked out and as susspected it didnt changed name while the .tp file contains ist name on the first line.
    So I got .ls file and changed the first line name to new name and this file i need to convert it in to .tp file if try to bin upload it shows file operation failed and file error.
    Edited once, last by rAviteja_g (September 10, 2018 at 9:35 AM).
  • dha
    28
    397
    • September 10, 2018 at 10:26 AM
    When I'm sending programs to robot with different names I also send additional text file that contains program name e.g. 'PROGRAM_1'.
    In MAIN program I first call RD_PRG_NM karel program that reads text file from PC and stores name into SR(x).
    After that I use instruction CALL SR(x).
    Edited once, last by dha (September 10, 2018 at 12:39 PM).
  • ravitejagali
    143
    • September 10, 2018 at 12:36 PM
    Quote from dha
    In MAIN program I first call RD_PRG_NM karel program that reads text file from PC and stores name into SR[x].
    After that I use instruction CALL SR[x].
    Karel Program? I have never used Karel, could you have any code for me.?
  • HawkME
    568
    10
    3,268
    • September 10, 2018 at 3:33 PM
    If you don't want to use karel you can also send the name directly to a string register.
  • Nation
    Typical Robot Error
    529
    1,910
    I do something similar for one of my customers, but I use another TP program to do it. I send over 2 programs, one that sets the program name string, and the actual program.
    : CALL PROG_NAME_SET ;
      : CALL SR[1] ;
    In this program, you would hardcode the name of the program that needs to be called.
    : CALL SR1_SET("MY_GREAT_PROGRAM") ;
    String registers can't be set directly in TP, so I use this argument workaround.
    :  SR[1]=AR[1] ;
  • ravitejagali
    143
    • September 10, 2018 at 4:39 PM
    It looks better solution but the problem is how do u get AR(1) or i have diffrent no of progrm in server, with barcode scanner i get path(server where robot program is ) and then i go tot hat path, change name and send it to robot. Here problem is first i get .ls programm.
    To change name inside .ls program is easy while first line i can delete and keep my text or programm name. But here while converting .ls to .tp file is difficult using batch, (ascii to bin)
  • ravitejagali
    143
    • September 11, 2018 at 7:50 AM
    We do it form PLC side, from HMI load programm is selected and by that the batch programm gets activated changes program, as you said in which form do i getthis string from PLC.? Could yu please.
    Now first send programto robot (by using ftp) --->then change name using karel program (But how do i fetch name uisng Input, I mean GI or some other way?)
    Edited once, last by rAviteja_g (September 11, 2018 at 9:21 AM).
  • ravitejagali
    143
    • September 14, 2018 at 10:15 AM
    • #11
    Hey Hi,
    Here Main is .TP prograem, Prog_NAME_SET and SR1_SET are karel program. What does AR[1] contains?
    Quote from Nation
      : CALL SR[1] ;
    :  SR[1]=AR[1] ;
  • pdl
    266
    1,508
    • September 14, 2018 at 7:48 PM
    • #12
    "MY_GREAT_PROGRAM"
  • bagged2drag
    79
    • September 14, 2018 at 11:25 PM
    • #13
    You can also set up a bar code scanner and hook it to the robot through a usb connection and scan it. Set up a webpage on the pendent with an active x button to modify the string register. Press enter and scan the barcode. It will write the scanned string to a string register. You can set up your main program to call that string register. It's been some time since I have messed with this. You could also write a Karel program to do the same thing and then you wouldn't need to interact with the pendent at all.
