KRC4 robot type change
  • hasan ekim
  • June 7, 2018 at 10:27 AM
  • hasan ekim
    19
    I have a welding robot KRC4 KR16L6-2 with 4 external axis
    KSS V8.3.29
    I will change the robot to Hollow Wrist type :KR16LHW C4 FLR ZH01
    What are the steps that I need to update in the controller? ( machine data,mada, kinematic etc??)
  • Mr.E
    41
    • June 8, 2018 at 10:39 AM
    Easiest way is to download project to WoV. Open the project, delete the robot and select your required one. All mada, etc. will be done for you.
    Save and redeploy!
    panic mode
    1,293
    13,122
    • June 8, 2018 at 8:49 PM
    [size=2]maybe.... but that is not complete instruction set. following it blindly can cause other problems.[/size]
    [font=verdana, arial, helvetica, sans-serif][size=2]make sure to setup WoV before doing anything - integrate KOPs and update DTMs for anything that project uses.
    [/size][/font]
  • hasan ekim
    19
    • July 25, 2018 at 3:49 PM
    downloaded the project, changed the robot type
    robot is working, external axis are working,
    But the external axis are not synchronous!!!
    robot and extrnal axis are mastered with EMD
    tool calibration OK
    base calibration are all OK
    SkyeFire
    1,059
    9,450
    • July 25, 2018 at 4:03 PM
    "Not synchronous" can mean many things. Provide details.
  • hasan ekim
    19
    • July 25, 2018 at 4:31 PM
    this is a welding robot which I need the 2 axis positioner (similar to DKP-400) must be moving syncronous with torch.
    normally when I move the external axis the torch is following the external axis and keeping the welding point fixed.
    T1B1 is choosen
    world coordinate sytem
    When I move E1;E2 axis torch is not following the positioner. ( all the other robots I have follow the positioner)
    $async_mode 2
    $async_axis 0
    $ex-ax-async 0
    after we changed the robot type to HW, everything is OK ( safety, remote connections, welding machine control etc ) except syncronous movement of positioners.
    SkyeFire
    1,059
    9,450
    • July 26, 2018 at 2:51 PM
    Have you performed the kinematic integration of the external axes, as outlined in the manuals?
  • hasan ekim
    19
    • July 26, 2018 at 3:03 PM
    tool, root point, base is calibrated.
    everthing seems green at startup wizard
    SkyeFire
    1,059
    9,450
    • July 26, 2018 at 3:20 PM
    Again... did you perform the kinematic integration?
    https://www.robot-forum.com/robotforum/man…84203/#msg84203
    Edited once, last by SkyeFire (July 26, 2018 at 3:22 PM).
  • hasan ekim
    19
    • July 26, 2018 at 4:39 PM
    what do you mena by "integration"; I could not find any integration part in the manual.
    According to manual
    Synchronous motions; Mathematically coupled: I just need to calibrate kinematic system. And I calibrated.
    I set the machine transformation data for kinematic machines at WoV
    Do I need to configure the cell as my Robot follows the external kinematic?
