I'm slowly progressing in my repairs of the KUKA KR3 robot with a KRC3(ed05? Made in 2007) controller, but I have encountered an issue I am struggling to fix.
When I boot the robot up, there are a few errors I am seeing that I would like to fix, but the two that worry me most are these:
When I run Monitor -> Diagnosis -> Safetycircuit, instead of the normal window I get this:
I have no idea where to begin looking at this issue, because there isn't anything in the manuals specifically related to the ESC board.
To further assist with the diagnosis, here is more information about the controller and robot in screenshots, text comments under images:
(KR C V5.2.15, GUI 1.2.32.0 B74, Kernal KS V6.74_39, DriveBus item #1 PM 2.24)
(KRC 3, #KR3 C3A FLR, No position accurate robot., 7123 hours, 6 axes, 0 external axes, all versions V6.6.0/KUKA5.2, DriveBus item #2 PM 2.24 )
(Windows version 5.1.2600, XPe V1.1.0 Build 10, BIOS version KUKA Roboter GmbH SY-7VBA133U/K V1.4.0/KUKA1030, DSE SW version 4-0, Processor Freq. 59MHz, Version C32)
(No options installed(?), MFC2 SW Version 4)
Launching the DSE-RDW tool shows that there's no data on the ESC diagnostics status and state register, and only ESC1 has some data:
On the hardware side, the backup/UPS batteries are missing(on their way), that fault is signaled in the log.
The MFC board seems to be functional, as is the DSE board - I can open up the drive bus section in the DSE-RDW diagnostic menu, the drives show up there and provide realtime encoder and voltage stats from the robot when I release the brakes(by pushing the 3 buttons on the robot body).
I have checked all the fuses in the entire controller, reseated most connectors(including the cards themselves), everything should be fine on that front.
All supplies except UPS(shows fault, no battery) and 76V(servo supply voltage, just turned off since drives aren't on) seem to be fine, but I don't know if there are any separate supplies on the ESC board I should be checking.
The ESC board is a "KUKA ESC CI2 V1.20 00-112-112".
On the ESC board itself, two LEDs are glowing - LED10 and LED11, close together. Nothing else is lit up.
I've followed the manual(physical) and installed this jumper configuration:
(6-12, 2-8, 21-27, 3-9, 22-28, 7-1, 26-20, 5-11, 30-24, 10-4, 29-23)
On the first boot when I got the robot, I also had some "defective brake" errors on A1 and A4, but those went away, and I could acknowledge them - they weren't persistent. That, and I don't care about A1 and A4 brakes, because they're not likely to move without them, and A1 brakes do work despite the error message.
Also, I should note that I do not have a KCP2 pendant, and I am unable to afford the exorbitant eBay and reseller prices, as that is close to what I paid for the entire robot. [size=4pt]If anyone has one of those for a sane price, let me know.[/size]
Where do I go from here? KUKA doesn't support this robot anymore(silence on their end), and I really want to get it running with the original controller.
[size=4pt](Side note: if anyone has the interface description for the Agile Systems servo drives, I would be very grateful)[/size]
