I've been having a play cutting foam with a spindle on the end of our KR10 KRC4
Everything is fine except I feel my programs are far from optimised as i'm plotting the shape to cut in 2D with X and Y and then running the program multiple times adjusting the base value by 15mm or so each time to change the Z axis for each cut.
Can anyone help with a method that can be done all in one program?
Cheers
Will
