Hey folks,
Firstly, thanks for the ridiculous amount of useful information you've all posted to this board in the past, it has proven invaluable to me. I've been tasked with setting up a pair of older GM KR150 robots running off of KRC1 cabinets in an incremental approach to automating our assembly here at my job. Up until this time there has not been a question either a search of this forum or a peruse through the programming manual hasn't been able to solve. For that again, I thank you.
I've come up with two questions though, one of which I've already managed to half answer, and they are as follows:
Question 1)
Currently I've mastered what we've deemed our R&D robot using the pen trick, not having either the EMT or dial indicator adaptor. To this point it has worked well enough to get proof of concept running, however when I go to a pre-production cell and then full production cell, I will be required to more accurately master the robot.
I've found rumor in a few threads of a pdf or drawing floating around where I could machine a dial indicator adapter to manually master the robot more accurately. Does anyone have a drawing or even a dimensional description of the adapter? I have the capability to make one in-house until I can secure an EMT.
Question 2)
This one is a little quicker, I've found a need to reach further on a particular operation than A2 and A3 will allow. I can extend the soft envelope in the programming to allow this but I've found I will hit the rubber and steel hard stops. Am I able to adjust these hard stops to allow for a greater range of motion, or are these set from the factory to protect internal cabling and hardware?
Thanks once again for your help, I'll continue to peruse the search function and manuals in the meantime to attempt to help myself.
