Hi there
I am using a CP 1604 (6GK1160-4AA01) module on our Fanuc robots. Siemens TIA Portal is the software I am using to interface between my PLC and robot controllers.
In the past, I would simple drag in a Fanuc GSD file into the hardware configuration, change the IP address and device name, and that would be it (I would have the robot controller on the network).
This is the first time I am using a Fanuc controller with the Siemens CP 1604 module and I am having difficulty getting communication. I have installed the CP 1604 GSD file on Portal V14 SP1, but when I right click on the module in the hardware and select “Configure PC station online” I get the following: (see attachments)
I contacted the local Fanuc branch, they gave me software to use to create a connection (PFNCT - Profinet Configuration Tool). I have tried everything on this software while following the manual but I am still not having any luck.
Am I missing something on the robot side? For instance, how do I create a connection between the CP card and the robot controller?
Any help would be greatly appreciated.
