What does the "SYNC( )" command do?
  • mbull
  • September 15, 2017 at 6:38 AM
  • mbull
    43
    I was hoping one of you could give me a little bit of enlightenment as to what the SYNC() command does, why it is needed, and how to get rid of the "SYNC()--CALL NOT PROGRAMMED" message upon shutting down the controller. The controller is a GM spec KRC2 running KSS 4.1.7 SP2.
    The operator control manual states the following in under the section titled "power failure with the system running"
    Quote
    An active application should react to the power failure with the KRL command “SYNC( )”.
    If this message does not appear, a corresponding error message is generated.
    It makes no difference whether the power failure was caused by failure of the mains supply
    or by pressing the main switch during program execution.
    The fault listing manual has the following to say:
    Quote
    Message text SYNC()--CALL NOT PROGRAMMED
    Cause -- In IRSTOPMESS, the user has failed to respond to $Power--Fail by calling the SYNC() function.
    Monitor -- During power failure.
    Effect -- None.
    Remedy -- Correct the application program.
    So does this mean that not calling SYNC() in ir_stopm has no effect? I find it hard to believe that kuka would have said message be displayed if SYNC() doesn't do anything.
    It appears that SYNC( ) is called within my my ir_stopm.src file:
    &ACCESS  R
    &COMMENT HandlerOnRobotFault
    DEF  IR_STOPM ( )
      ; Error Handling ROBOT CONTROLER
      ; Switch OFF and Switch ON process
      ;FOLD DECLARATIONS;%{PE}%V3.2.0,%MKUKATPBASIS,%CINIT,%VCOMMON,%P
      ;FOLD USER DECL;%{PE}%V3.2.0,%MKUKATPBASIS,%CINIT,%VCOMMON,%P
      ; Please insert user defined declarations
      ;ENDFOLD (USER DECL)
      ;FOLD BASIS DECL;%{PE}%V3.2.0,%MKUKATPBASIS,%CINIT,%VCOMMON,%P
      BOOL APPL_RUN_L,TMP_$STOPM
      DECL CHAR ID[3]
      ;ENDFOLD (BASIS DECL)
      ;ENDFOLD (DECLARATIONS)
      ;FOLD INIT;%{PE}%V3.2.0,%MKUKATPBASIS,%CINIT,%VCOMMON,%P
      ;FOLD BASIS INIT;%{PE}%V3.2.0,%MKUKATPBASIS,%CINIT,%VCOMMON,%P
      INTERRUPT OFF 3
      STOPM_FLAG=TRUE
      ID[]="CTL"
      IF $STOPMESS==TRUE THEN
        BRAKE
      ENDIF
      ;ENDFOLD (BASIS INIT)
      ;FOLD USER INIT;%{E}%V3.2.0,%MKUKATPBASIS,%CSPS,%VAUTOEXT,%P
      ; Please insert user defined initialization commands
      ;ENDFOLD (USER INIT)
      ;ENDFOLD (INIT)
      ;FOLD TOUCH STOP;%{E}%V3.2.0,%MKUKATPTS,%CSTOP,%VSTOP,%P
      IF H70_OPTION THEN
        IF (FG_ON_WORK AND ($OV_PRO==0)) THEN
          H70 (4,CD0 )
        ENDIF
      ENDIF
      ;ENDFOLD (TOUCH STOP)
      ;FOLD ARC10 STOP;%{E}%V3.2.0,%MKUKATPARC,%CSTOP,%VSTOP,%P
      IF A10_OPTION==#ACTIVE THEN
        A10(#IR_ERROR)
      ENDIF
      ;ENDFOLD (ARC10 STOP)
      ;FOLD ARC20 STOP;%{E}%V3.2.0,%MKUKATPA20,%CSTOP,%VSTOP,%P
      IF ARC20==TRUE THEN
        A20 (TECH_STOP1 )
      ENDIF
      ;ENDFOLD (ARC20 STOP)
      ;FOLD USER STOP;%{E}%V3.2.0,%MKUKATPUSER,%CSTOP,%VSTOP,%P
      ;Make your modifications here
      ;ENDFOLD (USER STOP)
      ;FOLD BASIS STOP;%{E}%V3.2.0,%MKUKATPBASIS,%CSTOP,%VSTOP,%P
        TMP_$STOPM=TRUE
        P00 (#EXT_ERR,#PGNO_GET,ID[],128 )
        APPL_RUN_L=FALSE
        IF (APPL_RUN>0) THEN
          IF $OUT[APPL_RUN] THEN
            APPL_RUN_L=TRUE
            $OUT[APPL_RUN]=FALSE
          ENDIF
        ENDIF
        REPEAT
          POWER=SYNC()
          HALT
        UNTIL (($STOPMESS==FALSE) AND ($POWER_FAIL==FALSE))
      ELSE
        TMP_$STOPM=FALSE
      ENDIF
      ;ENDFOLD (BASIS STOP)
      ;FOLD BASIS RESTART;%{E}%V3.2.0,%MKUKATPBASIS,%CRESTART,%VRESTART,%P
      IF TMP_$STOPM THEN
        P00 (#EXT_ERR,#PGNO_GET,ID[],0 )
        IF (($MOVE_BCO==FALSE) AND ($ON_PATH==FALSE) AND ( NOT ($MODE_OP==#T1)) AND ( NOT ($MODE_OP==#T2))) THEN
          IF (VARSTATE("$AXIS_RET")==#INITIALIZED) THEN
            PTP  $AXIS_RET
          ENDIF
        ENDIF
        IF APPL_RUN_L THEN
            $OUT[APPL_RUN]=TRUE
          ENDIF
        ENDIF
      ENDIF
      TMP_$STOPM=FALSE
      ;ENDFOLD (BASIS RESTART)
      ;FOLD USER RESTART;%{E}%V3.2.0,%MKUKATPUSER,%CRESTART,%VRESTART,%P
      ;ENDFOLD (USER RESTART)
      ;FOLD ARC10 RESTART;%{E}%V3.2.0,%MKUKATPARC,%CRESTART,%VRESTART,%P
      IF (A10_OPTION==#ACTIVE) THEN
        A10(#IR_RESTART)
      ENDIF
      ;ENDFOLD (ARC10 RESTART)
      ;FOLD ARC20 RESTART;%{E}%V3.2.0,%MKUKATPA20,%CRESTART,%CRESTART,%P
      IF (ARC20==TRUE) AND B_RESTART THEN
        A20 (13)
      ENDIF
      ;ENDFOLD (ARC20 RESTART)
      ;FOLD ;%{H}
      INTERRUPT ON 3
      STOPM_FLAG=FALSE
      ;ENDFOLD
    END
  • panic mode
    1,297
    13,141
    • September 15, 2017 at 8:42 PM
    that is a subroutine, not a command. if you want to see what it does, you need to find it first.
  • mbull
    43
    • September 17, 2017 at 5:26 AM
    Quote from panic mode
    I was just referring to it as what Kuka called it in the operator control manual. The thing is, I've already searched the contents of all .src files in the KRC folder and its subdirectories. The only occurrence of SYNC() that I can find is the following within ir_stopm:
    REPEAT
          POWER=SYNC()
          HALT
  • Fubini
    283
    1,905
    • September 18, 2017 at 7:53 AM
    SYNC() is a internal function (like FORWARD(), INVERSE(), ABS(), ATAN2(), ... ), so you will not find it in any source files. It is used for necessary internal synchronisations concerning power outage. So do not bother about ist.
    Fubini
  • matthiasjosef
    • July 6, 2021 at 2:48 PM
    Quote from Fubini
    Fubini
    Hello Fubini
    i have the same error message since today.
    i was working for weeks with my krc1 robot and all my programs worked fine. since today every time when i start a program "SYNC()--CALL NOT PROGRAMMED" appears and after a minute the controller shuts down and boots again.
    do you know how to solve this problem?
    best,
    Matthias
  • the leg
    643
    • July 7, 2021 at 7:57 PM
    possible motherboard issue that's the pc rebooting and the sync () is the power down function i believe
