Hello, can anyone help me with a question? I write new programms of arc-welding seams searching by KUKA. It's builded by interrupts of metal touching...like "TouchSense tech" KR16. Question is: I want to teach NEW base by three points (FRAME type) in the process of program-run (Not by menu: StartUp-->Base calibrate... ). Where can I find math libraries or algoritms for it, like standard KUKA's ? Thanks
BASE by three points
manhunt -
January 30, 2017 at 4:06 PM -
check forum, this was discussed before, there are also some ready to use program samples...
https://www.robot-forum.com/robotforum/kuk…rection-vector/
https://www.robot-forum.com/robotforum/kuk…lgorithm-works/EDIT --- updated links --- (2022-Oct)
PostRe: Computing A, B, C angles from the direction vector
Proper Euler angles only use two axis... for example Z-X-Z, etc. (first and third rotation are same, in this case Z). In reality they are not the same thing because Z axis points in different direction after second rotation.
Tait-Bryan uses three axes... X,Y and Z.
so there are three basic rotations involving all three axes (X,Y,Z), therefore this is considered Tait-Bryan....
just reverse the process or randomize A,B, C till you get right output.... kidding
you should check forum as this…panic modeSeptember 24, 2016 at 12:41 AM ThreadABC 3 point BASE measurement. How does algorithm works?
I want to perform ABC 3 point BASE measurement programmatically. Let's suppose I know the 3 point of the model and I can move the robot to it. Is it possible to call the measurement method in robot program?MischaDecember 25, 2014 at 9:01 AM -
Thanks a lot
As of the geometrical knowledge, it can be describled as the below procedures:
1. one out of 3 points can be as the base origin without angle(only translation)
2.calculate 2 vectors by 3 points(by origin)
3.achive the norm vector in x direction
4.calculator the norm vec
tor in z direction
5.calculate
the y vector ,
6.calculate
the euler angle by matrix
7.combine
the
translation and angle together
to get base frame.来自我的 MI 5s 上的 Tapatalk
Sorry for the late... somebody have the samples??
samples of what?
