Kuka 7th axis power cable
  • uberdoom
  • January 4, 2017 at 11:56 PM
  • uberdoom
    97
    Hello All,
    Not a very technical question, so move it if you must. I have a squished male end of a 7th axis power cable (motor of turntable to cabinet--the side that connects at the cabinet). Yes, I have contacted kuka but have not heard back for over a week now. I was wondering if anyone knew of where one might fight the male end terminal (I know it's a siemens motor but don't know if the fitting is proprietary). I can always buy another one, but that would be a big waste of $500. It's for a 1FK6100-8AF91-1ZZ9-Z S49 motor (size 1 cable via kuka standards).
    Thanks.
  • optimus_prime
    30
    • January 10, 2017 at 9:54 AM
    You can purchase the same from Harting, I think they use from Harting. Connector, Pins, Inserts etc.
  • M.Ozkan
    22
    5
    538
    • January 10, 2017 at 10:36 AM
    Motor connectors is Intercontec. You can found on Intercontec web site. Other is probably Harting.
  • panic mode
    1,295
    13,130
    • January 10, 2017 at 6:03 PM
    cables are different for different controllers (motor end is same but not controller end)
  • uberdoom
    97
    • January 11, 2017 at 12:28 AM
    Thanks for the info. It hooks up to the 7th axis wiring loom material number 00-129-763 for krc2 (size 1).
  • uberdoom
    97
    • February 17, 2017 at 9:14 PM
    For anyone in the same scenario: attached is the part information.
    Files
    BKUA186MR21480200000.pdf 144.1 kB – 99 Downloads
  • Martin84
    5
    366
    • February 19, 2017 at 10:29 PM
    http://www.tme.eu/en/details/750…-ls1-d6-5_pe-k/
    http://www.tme.eu/en/details/750…-ls1-f6-5_pe-k/
    Edited once, last by Martin84 (February 19, 2017 at 10:32 PM).
  • uberdoom
    97
    • February 22, 2017 at 1:22 AM
    So, I'm going to wire the connections and unfortunately came across to schematics for the motor cable. Doubly unfortunately I can only find one of them right now. I attached it. Can anyone confirm this is indeed correct? Thanks.
    Images
      • 27.06 kB
      • 706 × 329
      • 60
    Files
    7.1connector.JPG_thumb 7.07 kB – 54 Downloads
  • uberdoom
    97
    • February 27, 2017 at 1:32 AM
    bump...
    I thought is was U:1 V:4 W:6 brake (+):3 (-):5
  • panic mode
    1,295
    13,130
    • February 27, 2017 at 3:46 AM
    no,
    1,2,6 - motor phases
    3 - GND
    4,5 - Brake
