hi,im new to ABB ronot, i have bulk IO's to map and comment, is there any easy way to do that, i am facing difficulty by doing in TP
IO mapping and commenting
vipinpunneri -
November 10, 2016 at 3:42 AM -
Depending on which controller you have...
Robot Studio should make life easier on an IRC5.
On S4C, I usually edit EIO.cfg. -
For sure, it's better doing in Robotstudio!
You can also do it on the FlexPendant or editing EIO.cfg but could be longerInviato dal mio iPhone utilizzando Tapatalk
Personally, I think the fastest way is to Open the EIO file and directly edit it. But the RobotStudio option works well, too, just a little more clicking of the mouse.
Hi all,
Can someone tell me how to edit the DI on the flexpendant, I can see that a few already programmed, but I would like to change there name's and also combine some into a Group Input.
The controller is a S4C+
Hi all,Can someone tell me how to edit the DI on the flexpendant, I can see that a few already programmed, but I would like to change there name's and also combine some into a Group Input.
Ok, I found out how to do this:
1. In the I/O topic, choose the type Signal.
2. Add a new one or select an existing I/O signal to be changed or deleted.
3. Enter, delete, or change the values for the parameters. Set the parameter Type of Signal to
value Group Input or Group Output.
The required parameters depend on the type of signal. See parameter descriptions and
examples of typical configurations in the description of the type Signal.
4. Restart the controllerBut now I can only choose DI/DO AI/AO, does anyone know how I can choose Group input
Found it! underneath IO Signals is a tap called Type and there you can choose groups
To bad that you can only group a maximum of 16 bits together, I would like to have 18. Is this possible in a way?
