Hi guys,
My robot is KRC4 8.3.17. I want to change the A6's logical zero. I knew that the varlible $mames defines the difference between the logical and physical zero of an axis.
So I changed the $mames[6] to 60,but it can't work. Could someone help how to make it work or explain the varlible .Thanks a lot
How to use the $mames?
rain_maker -
October 29, 2016 at 6:40 PM -
I'm not entirely certain it's possible to change the $MAMES value for A1-A6. I would recommend making the change, then cold-booting the robot with "Reload Files" selected, then check to see if the changes were still present. The system may overwrite user-made changes to these values.
However, if you do change the $MAMES successfully, the change won't take effect until after you un-Master and Master the axis.
I've used mames[7] successfully on a dual robot linear track with two mastering posts so I could swap pts between them. Worked well. Didn't try changing values for 1 - 6.
...I want to change the A6's logical zero.Why?
The robot path have complited but The gripper on the flange has to rotated 60. if you have any suggesion about it ,please help me
Why?
The robot path have complited but The gripper on the flange has to rotated 60. if you have any suggesion about it ,please help me -
Have you tried using Edit -> Marked Region -> Transform Axis Specific to shift your program? Never used it myself so I'am not totally sure it works. But for cartesian shifts I would use the corresponding cartesian feature.
Fubini
If this is simply an issue where LIN moves have "wound up" A6 at the end of a path, you can resolve it by programming an unambiguous E6AXIS position that forces A6 back to a good starting position.
If you want to adjust A6's $MAMES value from inside a program, that cannot be done.
Are you using A6 in Endless mode?
Have you tried using Edit -> Marked Region -> Transform Axis Specific to shift your program? Never used it myself so I'am not totally sure it works. But for cartesian shifts I would use the corresponding cartesian feature.Fubini
Maybe it is a good idea,thank you
