KRL_FGETS
  • SkyeFire
  • August 4, 2016 at 9:47 PM
    SkyeFire
    1,059
    9,450
    So... has anyone been able to get "krl_fgets" to work, reading strings from text files? At the moment, I'm stumped.
    (it doesn't help that the manual is blatantly incorrect in several places, either...)
    So, I've tried multiple different things. My original text file lacked any special separator, and I kept getting an error that my buffer string (chFileLine[]) had an invalid character 'H0D'. The original version of my text file was DOS-style, with Carriage Return ('H0D') and Line Feed ('H0A') terminating each line. Since the krl_fgets is based on the classic Unix fgets, I took this to mean that the CR was causing my troubles, and I changed my text file to Unix-type line termination, with only LF at the end of each line.
    But, I still kept getting the invalid-character errors. So I added the ';' characters as separators, and changed my Separator value to match the ASCII value of ';'. Still no dice.
    Then, I tried doing away with the separator and line-end characters entirely -- I reformatted the entire ASCII file so that each line would be identical length (using leading 0s), and set the character limit to end one character before the fgets would reach either the ';' or the LF. The "invalid character" message changed to complaining that the invalid character was 'H00' (or 0x0, but that's the same thing).
    Still no good.
    So then, I tried changing the character limit to 10, which is much smaller than the line length. And I still get the "Invalid character 0x0" message, but the message says that the location of the invalid character is chFileLine[10]. Then I tried changing the limit value, and basically found that whatever I set the character limit to, I will get an "invalid character 0x0" error for that character in the chFileLine string.
    Along the way, I also tried things like clearing the chFileLine string, not clearing it, deliberately setting it in advance to various ASCII strings... I can definitely say that there are no Null (0x0) characters in that string when that message comes up, and the CWRITE is emphatically not making any changes to the string (which I've tried as both a static and runtime variable).
    At the moment, I'm just... stumped. The file is definitely opening successfully (I have a separate subroutine for that) and I'm getting a good handle for it (and the Close works properly on that handle), and I've had lots of success opening text files and writing to them. The text file is located in /KRC/ROBOTER/USERFILES, just as it should be. I'm not even getting to the SWRITE parsing yet. I simply cannot figure out what this thing is complaining about.
    As for errors in the manual:
    1. The Separator argument is listed as being "optional" -- it's not. Leaving it off generates a STATE.MSG_NO of -10 (incorrect number of arguments passed) without fail
    2. The Separator argument is shown as being type CHAR. It's not. Unless it's declared as INT (and it must be a variable, not an explicit value), MSG_NO -12 results (wrong data type). And my best guess is that it has to be set to the ASCII value of the separator character, but there's no way to be certain as yet.
    3. Maybe not an error? No mention is made of how fgets handles Unix line terminators vs DOS line terminators. My original suspicion was that the DOS-type terminators were causing issues, but I can't test that theory yet.
    Files
    ReadLineTest.dat 164.99 kB – 79 Downloads ReadLineTest.src 1.06 kB – 93 Downloads ArrayRead.TXT 2.52 kB – 87 Downloads
  • diglo
    7
    142
    • August 5, 2016 at 11:17 AM
    I've had the same problems too, when i had to read an array of points from a file, the KRL_FGETS didn't work properly and I finally ended up usinge KRL_FGETC and did all the parsing by myself...
    Files
    k_parse_file.dat 394 Byte – 74 Downloads k_parse_file.src 3.57 kB – 97 Downloads test.src 464 Byte – 80 Downloads
    SkyeFire
    1,059
    9,450
    • August 5, 2016 at 8:46 PM
    Trying that...
    Ow, what a chore. And now SWREAD is being buggy about parsing the bloody strings. :wallbash:
    And, it looks like "krl_feof" doesn't actually detect the end of the file -- another thing that directly contradicts the manual. In fact, "krl_feof" sets the Boolean False invariably, regardless of whether the end of the file has been hit or not. :censored:
    The silver lining is, I can check STATE.MSG_NO after "krl_fgetc" and get what appears to be a reliable, non-stopping check of whether I've hit the end of the file. So there's that much, at least.
    panic mode
    1,293
    13,122
    • August 5, 2016 at 8:47 PM
    i went through same pain a while ago, contacted big wigs and they confirmed that manual was wrong, some of parameters were not documented correctly and number of parameters was wrong. check one i posted in downloads section....
    i may need to look for my old files, eventually they worked....
    panic mode
    1,293
    13,122
    • August 5, 2016 at 9:00 PM
    can't find them but here is something i butchered together as a test sample...
    Files
    panic_read.src 1.04 kB – 188 Downloads
    SkyeFire
    1,059
    9,450
    • August 5, 2016 at 9:01 PM
    Thanks, Panic, I'll give that a shot.
    (edit)
    Hey, how did you get fgets to work with your separator shown as an explicit ";" character? When I tried that, I got a "not a variable" error first from CWRITE, then once I changed it to a CHAR in the DAT file and tried to use it, I got a "wrong variable type" error. The only thing I found that got me past those errors was making it an Integer ASCII equivalent.
    Edited once, last by SkyeFire (August 5, 2016 at 9:18 PM).
    SkyeFire
    1,059
    9,450
    • August 5, 2016 at 9:52 PM
    Okay, for a while there, I thought I was losing my marbles. :stupid:
    I put your program into my robot, changed the FOPEN to point at my test file, and it ran perfectly. I changed my test program to use FGETS again, and it failed utterly. And, as I said before, I could not put anything in as my Separator except an Integer variable. It was nuts.
    Until I put your CWRITE and my CWRITE up against the wall... I mean, against each other:
    cwrite ($FCT_CALL, s, m, "krl_fgets", h ,Buff[] ,87 ,Read, ";")
    CWRITE ($FCT_CALL, State, _Mode, "krl_fgets", nFileHandle, chFileLine[],100, nSeparator)
    Your CWRITE has one more argument than mine does. Where does that '87' come from? Your CWRITE has 9 arguments, where mine (and the manual) only show 8.
    Anyway, this should get me past the FGETS issue. Now I just have to get past the SREAD parsing issue.... :bawling:
    (edit)
    So, of course it turns out that my copy of the CWRITE manual was outdated. :wallbash: Anyway, thanks, Panic, you saved my bacon.
    (note to self, tell Werner this forum needs a bacon emoji....)
    Edited once, last by SkyeFire (August 5, 2016 at 10:02 PM).
    panic mode
    1,293
    13,122
    • August 5, 2016 at 10:07 PM
    as mentioned, i was just throwing this together to have some example code.
    the 87 is random number that should be longer than length of the line... just about any number would work.
    same is with read - i always initialize variables so i put some random value (it will be changed by CWRITE when line of text is read). :icon_wink:
    and you are using wrong manual... i already stated that i posted newer manual into download section of this forum :angel:
    SkyeFire
    1,059
    9,450
    • August 5, 2016 at 11:24 PM
    Yeah, I downloaded your newer version of the manual, which showed what I was doing wrong. But there's still some odd stuff happening.
    So, if my Buff[] string is declared in the DAT file, CWRITE always fails with a "invalid character" error, pointing at the first EOL character of the line in the text file. Changing the Buff[] variable to a runtime variable fixed that, but only insofar as CWRITE failed "silently", without crashing the program, but still gave me a STATE.MSG_NO of -11: "At least one function parameter has an invalid value."
    At this point, this is what my CWRITE and yours look like:
    cwrite ($FCT_CALL, s, m, "krl_fgets", h, Buff[], 87, Read, ";")
    CWRITE ($FCT_CALL, State, _Mode, "krl_fgets", nFileHandle, _chFileLine[], 100, nLineLength, ";")
    The only differences left between your code and mine (aside from the variable names) is that my nLineLength and State are declared in the .DAT file with initial values, so I can monitor them in the VarCor. I'll try changing that next. But seriously, if this function is going to treat runtime and retentive variables differently... WTF?
    SkyeFire
    1,059
    9,450
    • August 5, 2016 at 11:36 PM
    Nope. No go. I have officially hit the end of my rope. There is literally no functional difference between your code and mine that I can see, but the CWRITE gives me nothing but "At least one function parameter has an invalid value." I dunno, maybe I've just gone pie-eyed from staring at this code all day.
    &ACCESS RVP
    &REL 86
    &PARAM DISKPATH = KRC:\R1\Program\Test Programs
    DEF ReadLineTest ( )
      DECL INT      _nLineIndex, _nOffset, _nStringLimit, _nLineLength, _nColumnIndex, _nASCII, _nFileHandle
      DECL MODUS_T _Mode
      DECL CHAR    _chFileChar, _chFileLine[100]
      DECL STATE_T _State
      bEOF = FALSE
      _nLineLength = 1
      _nStringLimit = STRDECLLEN (_chFileLine[])
      WAIT FOR STRCLEAR (_chFileLine[])
      _nFileHandle = 0
      FileOpen("ArrayRead.txt", "r", _nFileHandle)
      IF (_nFileHandle <> 0) THEN
        _nLineIndex = 1
        _nColumnIndex = 1
        FOR _nColumnIndex = 1 TO STRDECLLEN (_chFileLine[])
          _chFileLine[_nColumnIndex] = " "
        ENDFOR
        WHILE NOT bEOF
         CWRITE ($FCT_CALL, _State, _Mode, "krl_fgets", _nFileHandle, _chFileLine[], 100, _nLineLength, ";")
         MsgNotify ("FGETS STATE.MSG_NO %1", "ReadLineTest", _State.MSG_NO)
          SWITCH _State.MSG_NO
          CASE 0
             _nASCII = _chFileChar
             SWITCH _nASCII
             CASE nSeparator
              ;Parse line into array
              _nOffset = 0
              ;SREAD (_chFileLine[], _State,_nOffset, "%g", ArrayVal[1,_nLineIndex].X)
              Increment (_nLineIndex)
              _nColumnIndex = 1
            CASE nLineFeed, nCarriageReturn
              ; Do nothing, keep reading
              ;until next valid char
            DEFAULT
              ; Get next character and append to line
              _chFileLine[_nColumnIndex] = _chFileChar
              Increment (_nColumnIndex)
            ENDSWITCH
          CASE -4
            bEOF = TRUE
            halt
          DEFAULT
            CWRITE ($FCT_CALL, _State, _Mode, "krl_fclose", _nFileHandle)
            bEOF = TRUE
          ENDSWITCH
    beof = true
        ENDWHILE
      ELSE
        HALT
      ENDIF
    END
    panic mode
    1,293
    13,122
    • August 6, 2016 at 6:36 AM
    • #11
    wow, seeing revision 86, this was... quite a battle. :icon_confused:
    sorry can't help you more, your code is incomplete, when i load it up there is bunch of compile errors due missing declarations and dependencies.. btw how do you know where the root problem is? do ou check inside FileOpen if file is really open? it didn't take long for me to notice that using CWRITE set of commands is a major pain in the rear. so in order to debug programs i practically ALWAYS place a check after EACH such operation (at least simple check of status flag).
    Edited once, last by panic mode (August 6, 2016 at 6:48 AM).
    SkyeFire
    1,059
    9,450
    • August 6, 2016 at 3:27 PM
    • #12
    Well, the FileOpen and FileClose subroutines are stuff I've got in my standard library of support functions, and they've been in production use for a year+ without any issues. And the STATE.MSG_NO I get from CWRITE (note the MsgNotify) isn't -3 (no file open), but -11 (at least one function parameter has an invalid value). Back when I had STATE decl'd as a retentive in the DAT file, I kept it open in the VarCor while I single-stepped through. On those occasions when the file didn't open, the error-handling caught it and skipped past the FGETS cleanly.
    Also, when I brute-forced it by replacing the FGETS with FGETC and concatenating, everything worked almost perfectly. I'm just trying to avoid the extra time cost -- I've got some huge arrays to load, so huge that I can't keep them all in KRC RAM simultaneously.
    panic mode
    1,293
    13,122
    • August 7, 2016 at 4:56 AM
    • #13
    Quote from SkyeFire
    thats the way i like it...
    Quote from SkyeFire
    parameter "Read" (second last) is using OUT transfer to tell how many characters are actually read in. this is why this one MUST be a variable. the separator is next parameter (last one) which is using IN transfer so it can be hardcoded.
  • tlambrop
    59
    • September 30, 2016 at 2:29 AM
    • #14
    KRC4 controller, KR30-3 robot, KSS 8.3.x
    I would like to bump this thread.
    I am having the EXACT same issue where I am getting my state message number to be -11 no matter what I do. I have tried using all 9 of the inputs. The file is opened and closed properly I presume (the state.ret1 == #data_ok after each file open, file read, and close is true).
    The last post on this thread suggested a possible problem may be with passing in a constant vs. a variable that is declared and initialized earlier in the program. I tried this and still did not get a working solution.
    Has anybody figured out the solution to this problem?
    Thanks!
    panic mode
    1,293
    13,122
    • September 30, 2016 at 2:16 PM
    • #15
    -11 means "At least one function parameter has an invalid value."
    so make SURE that all variables get INITIALIZED before you use them
    SkyeFire
    1,059
    9,450
    • September 30, 2016 at 5:33 PM
    • #16
    Yeah, the CWRITEs (at least using $FCT_CALL) seem to be really fussy about the variables. The buffer string can't be empty, you need to put something in it -- if you empty it with an STRCLEAR, the CWRITE appears to reject it (note: I haven't tested this exhaustively).
    I've also seen what appears to be issues with using static .DAT file variables as compared to identically-declared runtime variables. But again, I haven't tested this exhaustively.
    Also, avoid the mistake I made upthread and avoid the KSS 8.2 CWRITE/CREAD manual -- it's wrong for 8.3+.
    We've been sharing some working test code over in the CWRITE thread this week that you may find handy.
  • tlambrop
    59
    • October 3, 2016 at 3:46 PM
    • #17
    Alright, I will try to make sure everything is initialized as a run time variable.
    Worst case scenario I will have to use the "krl_fgetc" and splice all the chars together.
  • stokewoggle
    Guest
    • January 4, 2018 at 4:21 PM
    • #18
    I don't know if you got to the bottom of this in the end, but I have just spent the best part of the day on this same issue and have just resolved it. I wanted to post my findings so others can benefit and avoid the pain.
    The buffer size limit of your CWRITE krl_fgets call needs to be one less than the char array size.
    So in your case changing;
    CWRITE ($FCT_CALL, State, _Mode, "krl_fgets", nFileHandle, chFileLine[], 100, nSeparator)
    to;
    CWRITE ($FCT_CALL, State, _Mode, "krl_fgets", nFileHandle, chFileLine[], 99, nSeparator)
    should resolve it because your char array is declared as;
    DECL CHAR _chFileLine[100]
    Also, there is no need for the separator as far as my working version goes.
