It said the KONI is used for vision, but I wonder how does its IP configured? Would some one like to tell me ? thanks!
How to configure the KONI IP address?
irobot -
May 27, 2016 at 3:16 AM -
you install VisionTech and configure from there
thanks panic mode
I wonder whether this netcard could be used in Windows
may be refer to this thread: https://www.robot-forum.com/robotforum/kuk…ethernet-ports/ , but I will test it lately
KUKAHardwareManager.exe -assign OptionNIC -os WIN
KUKAHardwareManager.exe -assign OptionNIC -os RTOS
In fact you can only use it in Windows.
It will have no access to KSS.
I used KONI to do remote desktop. -
Hi KR16_2
Please elaborate, how did you configure KONI for remote desktop?
As irobot posted.
Run this from command line in windows on KRC4:
KUKAHardwareManager.exe -assign OptionNIC -os WINDon't remember where exactly this .exe is located (or if its in a path)
There is some stuff under c:\kuka\hardware...If I remember correctly you have to run it with KSS off so you will need external monitor and keyboard.
Once this utility runs it opens a window with log information. There is HELP or ABOUT that explains how to set IP and Netmask.
Once you set it connect network to KONI set your IP in a same range and you are good to go.
This is not designated use for that port as I was told this is for tech packages. But it works with windows just fine. -
Great. Thanks for explanation. I will try next time.
