intermittent alarm 4306 amplifier ready signal error
  • EthanASZ
  • March 21, 2016 at 5:02 AM
  • EthanASZ
    15
    so i am working on a up6 xrc 2001 that has been giving us intermittent alarm 4306, amplifier read signal error on axis L. i can reset the alarm, restart the servo power and the robot will work fine again, some times for a few minutes, sometimes it will run for the rest of the day with no more alarms. i would like to get this figured out and fixed before the robot craps out all together, but not sure where to start.
  • Pcarbines
    292
    • March 21, 2016 at 8:23 AM
    Hi , see attached, disturb plugs etc. with the turned Power Off !
    Files
    motomanXRCalarm4306.pdf 185.41 kB – 49 Downloads
  • EthanASZ
    15
    • March 22, 2016 at 7:09 PM
    since these parts are NOT cheep, i have a running ea1400, can i swap the wrca boards between robots to see if the problem stays with the up6 or if it fallows the wrca board to the ea1400. will swapping the wrca boards out be plug and play or will i mess up by abs data and have to remaster the robot? or would i be better off swapping the amplifiers out and leaving the wrca boards with there robots. i dont want to mess up my abs data on the ea1400 and risk both my robots being down.
  • Robodoc
    56
    7
    1,059
    • March 23, 2016 at 2:28 AM
    You can swap the WRCA cards as long as they have the same software version.
    Robodoc
  • Pcarbines
    292
    • March 23, 2016 at 7:08 AM
    Hi ,
    if your not sure of the correct procedure
    then Pay for a Motoman Service Engineer.
    You might need them to source a new part anyway.
    Files
    motomanXRCboardReplacement.pdf 1.33 MB – 27 Downloads
  • EthanASZ
    15
    • March 23, 2016 at 3:28 PM
    Quote from Robodoc
    how do i tell if the boards have the same software version? i know they have the same part number and they are both rev c [1][ 2][ 06].
    Edited once, last by EthanASZ (March 23, 2016 at 3:43 PM).
  • roboprof
    24
    467
    • March 23, 2016 at 8:07 PM
    Go to TOP MENU - SYSTEM INFO - VERSION. Check the system and boot software on the WRCA card. It will be listed at the bottom.
Users Viewing This Thread
  • 3 Guests
