addin 7th axis
  • happytriger2000
  • November 8, 2015 at 8:17 AM
  • happytriger2000
    327
    Hi all,
    I'm about to add an 7th axis rotary external axis to a KR60HA KRC2, this external axis does not need to be synchronus. I have changed the follwoing lines in Machine.dat:
    102 $RAT_Mot_AX[7]={N 529, D1}
    1329 INT $EX_AX_NUM=1 ;ANZAHL EXTERNER ACHSEN (0-6)
    1335 DECL ET_AX $ET1_AX={TR_A1 #E1,TR_A2 #NONE,TR_A3 #NONE} ;EXTERNE ACHSEN #NONE, #E1, #E2, #E3, #E4, #E5, #E6
    Something else is not quite right: the Traversing Mode shows only the robot, no external axis, is it because the external axis is not activated??
    Info: KRC V5.4.11
    KR60HA 3 C2 FLR ZH02
    windows version: 5.1.26
    THX,
  • happytriger2000
    327
    • November 8, 2015 at 8:42 AM
    In option.dat(STEU/option.dat), changed
    $ASYNC_OPT = false ---> $ASYNC_OPT = TRUE
    Edited once, last by happytriger2000 (November 8, 2015 at 9:21 AM).
  • happytriger2000
    327
    • November 8, 2015 at 9:20 AM
    Check the RDW BOX, the 7th axis connector is not plugged:
  • happytriger2000
    327
    • November 8, 2015 at 11:31 AM
    The Robot can not move....
    Machine data error 1541
  • markopo
    207
    • November 8, 2015 at 6:18 PM
    Hi.
    Maybe this will help You.
    Marek
    Files
    KRC2 External Axes - System software KSS5.5.pdf 5.48 MB – 156 Downloads
  • panic mode
    1,262
    13,027
    • November 8, 2015 at 8:32 PM
    be careful when editing mada manually, you can't modify structure (for example add new lines etc).
    there is quite a bit more to this than what you have done so far so read the manual and check previous posts.
    you must specify motor type, KSD, brake options etc.
  • happytriger2000
    327
    • November 9, 2015 at 4:53 AM
    To make sure that the external axis AC servo motor is not faulty, I disconnect A2 AC servo's power and resolver cable off a C1 Robot and use an extension cable to connect these 2 cable to the top of the External axis AC servo motor's power and resolver connector, both motor has the same spec:
    In theory if I jog A2 in KCP1 the external axis would turn, when I tried it non of the axes can be jogged. The cable were connected back as it was, and powered on C1 , jog A2, worked fine. Does this mean the External axis' AC servo Motor is faulty?
  • panic mode
    1,262
    13,027
    • November 9, 2015 at 3:01 PM
    could be motor or extension cables. you also don't mention what faults you get....
  • happytriger2000
    327
    • November 10, 2015 at 2:02 AM
    Hi Panic Mode,
    Got this error: 310- Safety Circuit for drives not ready
    If I change this line from 0 to 1, INT $EX_AX_NUM=1 ;ANZAHL EXTERNER ACHSEN (0-6), the robot cannot be jogged, I f I change it back to 0 the robot can be jogged.
    Also configured this:
  • happytriger2000
    327
    • November 10, 2015 at 4:32 AM
    the seller told me the following cable should be connected like this:
    Controller Robot
    X21 X41
    X21.1 X31
    the above can not be done, so has to be:
    X21 X31
    X21.1 X41
  • happytriger2000
    327
    • November 10, 2015 at 3:59 PM
    • #11
    Ok, found out the E1 encoder cable caused problem, got an error message on encoder cable, sort that out.
    Now, this:
    https://www.robot-forum.com/robotforum/kuk…66657/#msg66657
    "Ack. regulator limit exceeded E1"
  • happytriger2000
    327
    • November 12, 2015 at 11:54 AM
    • #12
    problem solved.
  • designfugitives
    • February 26, 2019 at 12:51 AM
    • #13
    happytriger2000 - what did you do to solve your problem? I'm getting the same message. thanks
