keep me logged in
  • vpomichal
  • August 3, 2015 at 4:15 PM
  • vpomichal
    35
    hi everyone,
    is it possible to keep me logged in as administrator ( or anything ) on kr c4?
    bit annoying always log in...
    thanks for your answers!
  • Robot_guy
    38
    • August 3, 2015 at 7:08 PM
    Following this will allow you to change the login time for the KRC4 Controller. Please before you send the cell to the customer revert the changes to the factory settings.
    1. You will need to first locate the file named “Authentication”. Location is in C:\KRC\SmartHMI\Config\Authentication.
    2. You will need to modify the value from 300 to 300000. There are three different locations that you have to modify, one is in “Lease time” and “Announcement” which has two different places you need to modify the value
    3. Once you have completed the modifications you will need to save the file and perform a cold start.
    If you switch to extended or auto you will have to log back in but this will allow you to set down the pendant for more then 5 minutes
    The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far is as needed? ~Duce
    Edited once, last by Robot_guy (August 3, 2015 at 7:16 PM).
  • vpomichal
    35
    • August 3, 2015 at 8:24 PM
    thank you so much, you made my life easier! :smiling_face: :merci:
  • Robot_guy
    38
    • August 3, 2015 at 8:40 PM
    Anytime
  • edkorea
    37
    • August 3, 2015 at 10:04 PM
    My recommendation, save authentication file to USB drive as backup.
    I've went thru the instruction and changed the 300 to 300000 on three locations.
    But, when I cold booted, there were some errors to load auto external files.
    I put the old authentication file back and rebooted, then it was loading without problem, but, expert mode is very short lived.
    I want to know how to stay "expert mode" even though change from T1 to External.
    Fubini
    278
    1,893
    • August 4, 2015 at 6:17 AM
    in <AutoLock>ModeOP2Aut ModeOP2Ext</AutoLock> remove ModeOP2Aut and/or ModeOP2Ext to not drop user lever when switching.
    Fubini
  • vpomichal
    35
    • August 10, 2015 at 6:21 PM
    thanks everyone!
  • MAsadRehman
    • February 2, 2023 at 11:53 AM
    same question? do you know how to solve it. I remember there is a xml file but the name i dont remember.
  • MHammer
    37
    • February 2, 2023 at 12:29 PM
    Quote from MAsadRehman
    Same question? do you know how to solve it. I remember there is a xml file but the name i dont remember.
    It is answered in #2, but I'll make it easy for you :winking_face:
    - Find C:\KRC\SmartHMI\Config\Authentication.config
    - Set <LeaseTime>0</LeaseTime> (Within the yellow box)
    - Restart controller
    I've got success with just altering the top most value.
    Edited once, last by MHammer (February 2, 2023 at 12:51 PM).
