Hello Great Robot Forum, Guys !
How and where can we see or get the Total number of Hours the robot ran.
Like a Lifetime Hours counter value or Runtime Hours. for KRC2 robots
Paul
Paul
If I remember correctly it should be in Robot Data where you can see Robot Name and running hours. Its been a long time I touched KRC2 but it should be there.
Thankyou RS
i will definitely look and update you .
But where is the Robot Data? du you mean machine data ? i will browse through....
thanks
paul
under help info depending on sw version
You can browse to the path:
Monitor>Hardware Info>Robot Runtime
It will show you the robot running time in hours which you can convert in desired format easily.
Or ask system variable $ROBRUNTIME. This should be the same.
Fubini
Hi everyone i want to know how to capture monthly data of running hrs of krc2 i want to run a progra that will automatic store monthly running hrs can anybody give some idea how to do this
