Calculating TCP
  • ambersat
  • June 26, 2015 at 7:16 PM
  • ambersat
    24
    Hi all,
    How compute TCP from 4 different point:
    Measured P1{ X -1212.375 ,Y 3785.411, Z 1180.433, A -0.93, B 47.263, C -92.214}
    Measured P2{ X -1150.558 ,Y 3911.037, Z 1180.013, A 48.827, B 47.309, C -92.209}
    Measured P3{ X-1464.654 , Y 3785.021, Z 1163.455, A 28.075, B -2.869, C -106.945}
    Measured P4{ X -1283.76 , Y 3676.609, Z 1132.282, A -26.651, B 20.973, C -71.511}
    I know how compute center of sphere, But I get :
    {X-1316,739144363, Y 3913,6685403798,Z 845,4296028114 }, this is reference point of measure, but I need compute relative to the Flange system
    KUKA compute:
    {X 175.143,Y 301.955, Z 139.15}
    How get these result mathematically?
    Robot: KUKA KR210
    Edited once, last by ambersat (June 27, 2015 at 1:22 PM).
  • Go to Best Answer
  • panic mode
    1,267
    13,033
    • June 27, 2015 at 1:40 AM
    first you need to know what P1-P4 really represent (what tool and base?).
  • ambersat
    24
    • June 27, 2015 at 7:32 AM
    Hi
    P1-P4
    $TOOL = $BASE = $NULLFRAME
  • panic mode
    1,267
    13,033
    • June 27, 2015 at 5:37 PM
    I assume you already did sanity checks and verified that points are on sphere etc.
    what do you get if you use
    INV_POS(P1):PC
    where PC is frame with your computed sphere center
  • ambersat
    24
    • June 29, 2015 at 8:59 AM
    Quote from panic mode
    INV_POS(P1):PC
    {POS: X 173.8236, Y 300.3997, Z 138.2551, A -47.26606, B 6.962621E-01, C 91.50240},
    This is great, but how to get this answer mathematically?
  • Puck
    17
    • June 29, 2015 at 12:20 PM
    Take a look at the german robot forum:
    http://www.roboterforum.de/roboter-forum/…g55090#msg55090
    Calculate the flange orientation matrices and flange positions from the four flange frames:
    R_1 * t + r_1 = P with orientation matrix R_1 = R_1(A_1, B_1, C_1) and position r_1 = [X_1, Y_1, Z_1]^(T)
    R_2 * t + r_2 = P with orientation matrix R_2 = R_2(A_2, B_2, C_2) and position r_2 = [X_2, Y_2, Z_2]^(T)
    R_3 * t + r_3 = P with orientation matrix R_3 = R_3(A_3, B_3, C_3) and position r_3 = [X_3, Y_3, Z_3]^(T)
    R_4 * t + r_4 = P with orientation matrix R_4 = R_4(A_4, B_4, C_4) and position r_4 = [X_4, Y_4, Z_4]^(T)
    The vector t = [X_TCP, Y_TCP, Z_TCP] is the unknown TCP and the point P is the reference point used by the XYZ 4-point method.
    Rearrange the equations and eliminate the reference point P:
    R_1 * t + r_1 = R_2 * t + r_2
    R_1 * t + r_1 = R_3 * t + r_3
    R_1 * t + r_1 = R_4 * t + r_4
    Rearrange:
    [R_1 - R_2] [r_2 - r_1]
    [R_1 - R_3] [ t ]= [r_3 - r_1]
    [R_1 - R_4] [r_4 - r_1]
    9x3 3x1 9x1
    Solve the overdetermined system of the form A x = b. Good luck :zwink:
    Bye Puck
  • fares f
    • March 1, 2021 at 8:34 PM
    HI ambersat
    CAN I KNOW WHAT ARE YOU USING FOR COMPILING .
    IM WORKING ON TCP CALIBRATION ALGORITHM AND I FACED SAME PROBLEM .
    (IM USING MATLAB FOR MY CALCULATION)
  • panic mode
    1,267
    13,033
    • March 1, 2021 at 9:52 PM
    "INV_POS()" and geometric operator ":" are KRL functions
  • micahstuh
    7
    31
    • March 1, 2021 at 10:12 PM
    Here is some code I wrote for a C# application. It may not be super helpful given the language you're working in but here's hoping.
            /// <summary>
            /// Calculate the XYZ values of a tool
            /// </summary>
            /// <param name="samples">Position samples using $NULLFRAME as $TOOL</param>
            /// <param name="error">Average error between samples from calculated TCP</param>
            /// <returns>Final TCP data</returns>
            private double[] CalculateTCP(List<double[]> samples, out double error)
                // Convert matrices from samples to prepare for linear algebra
                var a = new double[samples.Count, 4];
                var f = new double[samples.Count, 1];
                for (int i = 0; i < 3; i++)
                    for (int j = 0; j < samples.Count; j++)
                        a[j, 3] = 1;
                        a[j, i] = samples[j][i] * 2;
                        f[j, 0] += Math.Pow(samples[j][i], 2);
                // Solve for system of linear equations using Guass Elim
                double[,] c = Transpose(GaussianElimination(f, a));
                // Find radius of sphere in which A6 flange falls on
                double radius = Math.Sqrt(c[0, 3] + Math.Pow(c[0, 0], 2) + Math.Pow(c[0, 1], 2) + Math.Pow(c[0, 2], 2));
                // Get the average inverse transformation from center of sphere to A6 flange
                var avgTcp = new double[3];
                var tcpGuess = new List<double[]>();
                for (int i = 0; i < samples.Count; i++)
                    tcpGuess.Add(InvTransformPoint(c, samples[i]));
                    for (int j = 0; j < 3; j++)
                        avgTcp[j] += tcpGuess[i][j];
                    avgTcp[i] /= samples.Count;
                // Calculate error average
                error = 0;
                    error += Distance(tcpGuess[i], avgTcp);
                error /= samples.Count;
                return avgTcp;
  • panic mode
    1,267
    13,033
    • March 2, 2021 at 5:51 AM
    • Best Answer
    http://www.convertalot.com/sphere_solver.html
    and btw, one can right click on page and view source to see Java code:
    <!-- hide
    var zero = parseFloat("0");
    var Xo, Yo, Zo;
    var P = [[zero,zero,zero],[zero,zero,zero],[zero,zero,zero],[zero,zero,zero]];
    // evaluate the determinant
    function compute()
        P[0][0] = parseFloat(calc.x1.value);
        P[0][1] = parseFloat(calc.y1.value);
        P[0][2] = parseFloat(calc.z1.value);
        P[1][0] = parseFloat(calc.x2.value);
        P[1][1] = parseFloat(calc.y2.value);
        P[1][2] = parseFloat(calc.z2.value);
        P[2][0] = parseFloat(calc.x3.value);
        P[2][1] = parseFloat(calc.y3.value);
        P[2][2] = parseFloat(calc.z3.value);
        P[3][0] = parseFloat(calc.x4.value);
        P[3][1] = parseFloat(calc.y4.value);
        P[3][2] = parseFloat(calc.z4.value);
        // check input
        if (isNaN(P[0][0])||isNaN(P[0][1])||isNaN(P[0][2])||
            isNaN(P[1][0])||isNaN(P[1][1])||isNaN(P[1][2])||
            isNaN(P[2][0])||isNaN(P[2][1])||isNaN(P[2][2])||
            isNaN(P[3][0])||isNaN(P[3][1])||isNaN(P[3][2]))
            window.alert("Invalid input!");
            return;
        var r = sphere();
        if (r > 0)
            calc.x0.value = Xo;
            calc.y0.value = Yo;
            calc.z0.value = Zo;
            calc.r0.value = r;
        else
            calc.r0.value = "Not a sphere";
    // Calculate center and radius of sphere given four points
    function sphere()
        var i;
        var r, m11, m12, m13, m14, m15;
        var a = [[zero,zero,zero,zero],[zero,zero,zero,zero],[zero,zero,zero,zero],[zero,zero,zero,zero]];
        for (i = 0; i < 4; i++)                    // find minor 11
            a[i][0] = P[i][0];
            a[i][1] = P[i][1];
            a[i][2] = P[i][2];
            a[i][3] = 1;
        m11 = determinant( a, 4 );
        for (i = 0; i < 4; i++)                    // find minor 12
            a[i][0] = P[i][0]*P[i][0] + P[i][1]*P[i][1] + P[i][2]*P[i][2];
            a[i][1] = P[i][1];
            a[i][2] = P[i][2];
            a[i][3] = 1;
        m12 = determinant( a, 4 );
        for (i = 0; i < 4; i++)                    // find minor 13
            a[i][1] = P[i][0];
            a[i][2] = P[i][2];
            a[i][3] = 1;
        m13 = determinant( a, 4 );
        for (i = 0; i < 4; i++)                    // find minor 14
            a[i][1] = P[i][0];
            a[i][2] = P[i][1];
            a[i][3] = 1;
        m14 = determinant( a, 4 );
        for (i = 0; i < 4; i++)                    // find minor 15
            a[i][1] = P[i][0];
            a[i][2] = P[i][1];
            a[i][3] = P[i][2];
        m15 = determinant( a, 4 );
        if (m11 == 0)
            r = 0;
        else
            Xo =  0.5*m12/m11;                     // center of sphere
            Yo = -0.5*m13/m11;
            Zo =  0.5*m14/m11;
            r  = Math.sqrt( Xo*Xo + Yo*Yo + Zo*Zo - m15/m11 );
        return r;                                  // the radius
    //  Recursive definition of determinate using expansion by minors.
    function determinant( a, n )
        var i, j, j1, j2;
        var d = parseFloat("0");
        var m = [[zero,zero,zero,zero],[zero,zero,zero,zero],[zero,zero,zero,zero],[zero,zero,zero,zero]];
        if (n == 2)                                // terminate recursion
            d = a[0][0]*a[1][1] - a[1][0]*a[0][1];
        else
            d = 0;
            for (j1 = 0; j1 < n; j1++ )            // do each column
                for (i = 1; i < n; i++)            // create minor
                    j2 = 0;
                    for (j = 0; j < n; j++)
                        if (j == j1) continue;
                        m[i-1][j2] = a[i][j];
                        j2++;
                // sum (+/-)cofactor * minor
                d = d + Math.pow(-1.0, j1)*a[0][j1]*determinant( m, n-1 );
        return d;
    // unhide -->
  • fares f
    • March 2, 2021 at 2:58 PM
    • #11
    thank you so much :smiling_face::smiling_face:
  • fares f
    • March 2, 2021 at 3:34 PM
    • #12
    I was able to calculate the center of the sphere, but I can't use this point to get the TCP .
    {X 446.54, Y 47.42,Z 361.08 }, this is reference point (the center of the sphere), but I need compute relative to the Flange system which is { X 91.818 , Y -1.55 ,Z 215.789 } computed by KUKA
    THANK YOU
    Edited once, last by fares f (March 2, 2021 at 4:13 PM).
  • panic mode
    1,267
    13,033
    • March 2, 2021 at 4:03 PM
    • #13
    Quote
    relative to the Flange system witch is { X 91.818 , Y -1.55 ,Z 215.789 }
    that is a witch...
    to do a transform, it is not enough to know flange translation, one also needs flange orientation.
    translation is only a vector indicated by X,Y,Z. orientation is defined by angles A,B,C.
    orientation angles are needed to form 3x3 rotational matrix which is key part of the general transform.
    transform combines rotation matrix and translation into 4x4 matrix. multiplication by this 4x4 matrix is what KUKA calls geometric operator etc.
  • fares f
    • March 2, 2021 at 4:24 PM
    • #14
    that is a witch...
    that's what i did .i have my own forward kinematics and it works good (same results as those for KUKA).
    and as i told you i got the reference point which is the center of sphere by 4 point method . all what i need now is how to Get the average inverse transformation from center of sphere to A6 flange.
    thank you .
  • micahstuh
    7
    31
    • March 2, 2021 at 4:28 PM
    • #15
    Herse some more C# but it should be pretty easy to read.
            public static double[] InvTransformPoint(double[] point, double[] origin)
                // If point=TransformPoint(pointOriginal, origin)
                // Then this will give pointOriginal given point and origin
                // If that makes sense...
                double[,] oTI = Transpose(RotToMat(origin[3], origin[4], origin[5]));
                double[] oPosI = MatMult(MatNeg(oTI), GetRange(origin, 0, 2));
                double[] oRotI = MatToRot(oTI);
                double[] pointOut = new double[3];
                pointOut[0] = oTI[0, 0] * point[0] + oTI[0, 1] * point[1] + oTI[0, 2] * point[2] + oPosI[0];
                pointOut[1] = oTI[1, 0] * point[0] + oTI[1, 1] * point[1] + oTI[1, 2] * point[2] + oPosI[1];
                pointOut[2] = oTI[2, 0] * point[0] + oTI[2, 1] * point[1] + oTI[2, 2] * point[2] + oPosI[2];
                return pointOut;
    point has 3 elements XYZ, origin has 6 elements XYZABC, and return has 3 elements XYZ
    GetRange is taking a subset of a 1D array.
    MatNeg is negating a matrix.
    MatToRot is getting A,B,C values from a rotation matrix.
    Edited 2 times, last by micahstuh (March 2, 2021 at 4:41 PM).
  • panic mode
    1,267
    13,033
    • March 2, 2021 at 8:24 PM
    • #16
    you need angles
    Quote
    that's what i did ....all what i need now is how to Get the average inverse transformation from center of sphere to A6 flange.
    not that i can see, your post only shows translation (X,Y,Z):
    Quote
    if center of sphere is at {X 446.54, Y 47.42,Z 361.08 }
    and flange is at { X 91.818 , Y -1.55 ,Z 215.789 }
    you get infinite number of solutions because robot can rotate about center of the flange so that center would still be at { X 91.818 , Y -1.55 ,Z 215.789 } but orientation angles would be different.
    if you want to know how to get from flange to center of sphere it is important to know the flange orientation.
