hi dear
im trying to install english windows 95 on Krc1 controller
but in install section in 96% it give me stack over flow
where is the problem?
windows 95 installation stack overflow on KRC1
ebb -
May 13, 2015 at 8:56 AM -
how much memory is installed and is it ok? (memory test?)
thanks for your attenttion
system have 132Mb memory
i extended to 164 but i have the same problem. -
I think the problem is the KRC1 controller
Very old components. So it's possible that the mainboard has been died. If for example the capacitors are weak, the controller runs for a while and then there happen different strange things.
So check all components and try with changing them one after the other. Or at first have a look for all the 'bigger' capacitors on the mainboard. -
hello dears
can anybody help me.
I have this problem yet
when I was trying to install win95
it progress some minutes and then I have stack over flow.
if I have a hardware problem, why I can start to setup.dose anybody had this type of error.
