How to use Fast Measurement inputs?
  • Mischa
  • April 2, 2015 at 7:53 AM
  • Mischa
    10
    113
    I use KRC4 and Heidenhain Probe TS 460 with SE 660 for interrupt activation. The sensor works correct and gives trigger signal. :justice: The trigger signals connected to 2 and 3 (inverted trigger signal) outputs of X33 socket. How I can see it at robot side? How to declare it (INTERRUPT DECL 21 WHEN ??? = TRUE DO STOP() )?
    Edited once, last by Mikail (April 2, 2015 at 7:54 AM).
  • the leg
    643
    • April 2, 2015 at 8:24 AM
    $meas_puls[1]
  • Mischa
    10
    113
    • April 2, 2015 at 10:05 AM
    Can I see does it work without running the program? Similar to Display > Analog I/O
  • Fubini
    278
    1,889
    • April 2, 2015 at 10:35 AM
    In Display->Variable->Single you can enter and watch any $variable you like.
    Fubini
  • Mischa
    10
    113
    • April 2, 2015 at 1:21 PM
    Ohh. I tried to see the $meas_puls[1] (or any [1-4]) in Display->Variable->Single, but it didn't work. There is no error. I just see "" (Quotation Mark). I checked all connections and sensor really gives trigger signal to first pin of X33 socket or second pin of X23 socket. What can be the problem?
    Edited once, last by Mikail (April 2, 2015 at 1:56 PM).
  • sjx
    25
    96
    • April 2, 2015 at 1:55 PM
    You have to activate it in WorkVisual.
    Look for menu's like Options....properties
    or make it manually
    C:\KRC\Roboter\Config\User\Common\Mada\KRCAxes.xml
    delete the comments:
    <!--MeasureChannel ID="1"/>
    </MeasureChannels>
    should be:
    <MeasureChannels>
    <MeasureChannel ID="1"/>
    <MeasureChannel ID="2"/>
    <MeasureChannel ID="3"/>
    <MeasureChannel ID="4"/>
    <MeasureChannel ID="5"/>
    <MeasureChannel ID="6"/>
    <MeasureChannel ID="7"/>
    <MeasureChannel ID="8"/>
    </MeasureChannels>
  • Mischa
    10
    113
    • April 2, 2015 at 3:05 PM
    I corrected it manually, but...
    it was only single line of code:
    </MeasureChannels>
    I changed all to:
    <MeasureChannels>
    </MeasureChannels>
    But again it didn't work :wallbash:
  • Mischa
    10
    113
    • April 2, 2015 at 4:19 PM
    I forgot to restart the KRC. Cold reboot did all trick. Thank you :merci:
  • diglo
    7
    142
    • April 8, 2015 at 4:36 PM
    The variable name is $MEAS_PULSE[1] ... [4]
