Hi
I write simple program and divided to 3 subprogram and run all of them in main program.
in the first subprogram i set OUTPUT and in last subprogram i reset that output.
in manual mode everything OK , but in AUTO mode , output get off when second subprogram started!!!!
PLEASE tell me , how can solve this?
output not remain "ON"
NASERKARGAR -
February 2, 2015 at 8:41 AM -
post your code! there could be many reasons for this, so without the code it is impossible to determine what is going wrong
Leon is right.
How many motion commands are there between the Output-on and Output-off commands?
let me guess, you are using inline form instruction OUT and you chose option CONT
And $ADVANCE at the default 3 -
Hi
Many Thanks for Your Attention.
I will going to bring program here
Yes Your Right , i did it as you say. -
well... that is not a good combination. time to learn about SYN OUT instruction (if you want inline form) or swap it with $OUT_C[] (if you don't mind typing KRL)
