Expert mode in vkrc2 Xp
  • trunkcnc
  • December 8, 2014 at 10:46 PM
  • trunkcnc
    70
    Hi all Im trying to set a vkrc2 into a expert mode with xp but dont know the mode. With w95 is easy all you need is a cd with the key file. Any ideas ?????
    Do what you think but think what yo re going to do...
  • massula
    205
    8
    1,439
    • December 13, 2014 at 6:20 AM
    Hello, trunkcnc.
    For VKRC2 ed05 (this one that comes with XP), the procedure is the same, but instead a CD you will use a usb stick. And, if I recall correctly, the keyfiles folder for theese robots should have three files.
    Enviado do meu GT-I9505
  • trunkcnc
    70
    • December 13, 2014 at 3:26 PM
    Thanks massula but mines arent ed05 ?????
  • massula
    205
    8
    1,439
    • December 13, 2014 at 11:30 PM
    Hey, trunkcnc.
    If your robot is running Windows XP, so it is a ed05.
    But the best way to check this is the VSS version. 3.3.x are for old VKRC2 (with Win95). 5.4.x are for the latest ones (with WinXP).
  • trunkcnc
    70
    • December 14, 2014 at 1:52 PM
    Do u mean that xp can only be running with ed05 cabinets ????
  • trunkcnc
    70
    • December 14, 2014 at 1:53 PM
    Mines are vkrc 2002-2004 cabinets
  • massula
    205
    8
    1,439
    • December 14, 2014 at 2:00 PM
    Yep. I've heard about someone in a VW plant here in Brazil performing some tests with WinXP in old VKRC2 cabinets. But normally you only run XP on newer ed05 cabinets, because you had some hardware incompatibilities, and so on.
  • trunkcnc
    70
    • December 15, 2014 at 10:45 AM
    Massula we have vw soft in krc2 working. That is not problem. It works fine. The problem now is that we cannot opent expert level
  • trunkcnc
    70
    • December 15, 2014 at 10:47 AM
    Xp I mean
  • massula
    205
    8
    1,439
    • December 15, 2014 at 11:12 AM
    So, your expert cd isn't working? Or your cd drive? Because, as you wrote some posts ago, all you need is a cd with a folder called Keyfiles, with two text files inside.
  • trunkcnc
    70
    • December 15, 2014 at 2:37 PM
    • #11
    Hi. I have tryed to get into expert level with a pen drive but it doesnt work. We only have one key file. We have tried with cd room but didnt work neither. The only cd file we have is called key_2.txt. what other file are we missing?
  • trunkcnc
    70
    • December 16, 2014 at 10:54 AM
    • #12
    Quote from massula
    Hello, trunkcnc.
    Hi massula. What are the others files for setting expert level we need? We have key_2.txt . Do we need any other file?
  • massula
    205
    8
    1,439
    • December 16, 2014 at 12:40 PM
    • #13
    Hi, trunkcnc.
    Normally, the expert cd for VKRC2 have a keyfiles folder with two files inside: key_1.txt and key_2.txt.
    But key_1.txt is intended for VKRC1, so your key_2.txt should work.
  • massula
    205
    8
    1,439
    • December 16, 2014 at 12:41 PM
    • #14
    But, your cd-rom is working fine?
  • trunkcnc
    70
    • December 16, 2014 at 1:47 PM
    • #15
    Nope. With that file doesnt work. I know that it should but it doesnt
  • trunkcnc
    70
    • December 16, 2014 at 3:09 PM
    • #16
    We have tried also with usb pen drive. But no luck neither
  • trunkcnc
    70
    • December 16, 2014 at 3:30 PM
    • #17
    By the way our soft version is 5.4.7
  • massula
    205
    8
    1,439
    • December 16, 2014 at 4:02 PM
    • #18
    Aha!
    VSS 5.4.7 is VKRC2 ed05 software.
    The expert mode on this VSS is a little bit tricky.
    First, you will need a third file inside your keyfiles folder, called ExternalUserList.config
    Second, by default you will need two usb sticks attached to the controller. The first one will be recognized as drive A:. The second one will be recognized as drive E:, and the robot will search for the keyfiles folder in this last one.
    If you put only one usb stick, the controller will find only the drive A:.
    You can change this configuration after, with KRCCONFIGURATOR, but I don't recomend do this if this robot is still inside a VW plant :winking_face:
  • trunkcnc
    70
    • December 16, 2014 at 10:16 PM
    • #19
    Brilliant Massula. I havent tryed yet but it makes a lot of sense [emoji3] . Any way is weird that we can run ed05 soft in vkrc2 cabinets. Mfc2 is isa plugged board and ed05 is mfc3 pci. But i swear u that it works. [emoji28] ill post a picture. We deal with used kuka robots and rigth now we re conditioning these vkrc2. They re great machines
  • javaman
    5
    318
    • August 5, 2019 at 9:43 AM
    • #20
    I got a used vkrc2 and i found on kuka_data partition 5.4.7 HF5 software.
    Can this software can be installed to windows embedded standard or posready 2009 (based on win xp sp3)?
    Also can this software installed on other vkrc2 i have with windows 95 (after upgrade to xp)?
    I mean if can be installed because of license reasons.
    Where is located the key for expert mode?
