Our XRC up6 was stored for too long. I need help getting the teach pendant back to English. Thanks in advance.
XRC TEach pendant in Japanese
ironcollarworker -
December 2, 2014 at 6:17 PM -
press and hold SHIFT key and press Area.... try it
this works for the Dx100 -
Hi ,
I'm unaware of any method in XRC to setup the language , other than being in "Maintenance Mode " & Yaskawa code > system > setup > language ( you can then setup 1 language & 2 language)
That also means that the Multiple languages are installed in XRC , which is not Always the case.
Too toggle between the two languages 1 or 2 ( I've forgotten ) I'm sure some one will post it. -
uae the metodhe that Eli say. it is working, but is strange to need to do that ..
Still no luck with this. ED
Is your memory still intact, or did you lose all the jobs? If so, you may need to replace the battery and reload in your backups.... maybe even re-initialize the robot. If the battery went dead, it is common for the robot to power up in Maintenance mode and in Japanese....
If CMOS is lost due to dead battery load CMOS.bin under maintenance mode.(it will be in Japanese) and you do not have CMOS.bin file the robot must be initialized
It worked Thanks!
