Hi
I have a Vkr200/2 with KRC1 with the next error:
"266 sobretemperatura de resistencia de descarga o ventilador"
i clean the fan check connections , and still the error
what its wrong?
thanks a lot
Hi
what its wrong?
thanks a lot
Have you check the resistor?
extactly which resistor ?
ballast resistor, it is generally on the back side of the cabinet and cooled by external fan (not seen one on KRC1 but should be all same). it looks like heater element (which it is) and resistance should be stated on your schematics (11 Ohm for example).
Krc2 21 ohms
