  4. ABB Robot Forum
ABB2400 error
  • soorena_79
  • August 30, 2014 at 9:13 PM
  • Eli
    83
    • July 29, 2022 at 4:45 PM
    • #21
    last 3 rev.counters values are erased on arm, I can't enter values from arm into calibration offsets
    Lemster68
    301
    2,469
    Blog Articles
    7
    • July 29, 2022 at 4:54 PM
    • #22
    OK, I see. SO you have not even had it running yet doing anything. I think that the best thing to do at this point would be to enter the calibration offsets that you can read. Should be in the Service? menu. Then line up all the rev counter markers. Tip: do 4, 5 and 6 first, you can have it down near you on the floor instead of climbing the robot or a ladder to see them. Then you change to the major axes and line them up. Only thing that I think you can do for the other illegible axes is to fine calibrate those axes. Again, Service menu. After that and any necessary rev counter updates, check the zero position. Enter a MoveAbsJ with a jointtarget that is all zeroes. Use \NoEOffs. Check that the mark are lined up still. Any little sliver off is no cause for panic. It only matters if it is like one motor revolution off, which can be much more noticeable. Make a backup, write down the calibration offsets and guard them with your life.
  • Eli
    83
    • July 29, 2022 at 5:07 PM
    • #23
    Also how do i update the cfg data. As of now i cant even jog the arm due to mismatch error
    Lemster68
    301
    2,469
    Blog Articles
    7
    • July 29, 2022 at 5:45 PM
    • #24
    That again will be in service menu. Aside from the calibration offsets the is the commutation. There will be a column in which there will be a yes or no for the flag. You will have to set them to true. In that generation of robot it should be 1.5708 commutation offset. Half of Pi.
    Have you yet downloaded the manual referenced in an earlier reply from another user?
  • Eli
    83
    • July 29, 2022 at 6:19 PM
    • #25
    manual was for irc5 controller
    I downloaded s4cplus manual but can't find anything as far as to how to update cfg data
    Lemster68
    301
    2,469
    Blog Articles
    7
    • July 29, 2022 at 6:51 PM
    • #26
    Did you get this one?
    Thread
    User's Guide for BW 4.0 r119
    As requested by FriendlySteak
    Skooter
    September 14, 2019 at 1:37 AM
  • Eli
    83
    • July 29, 2022 at 6:52 PM
    • #27
    the mismatch error is not coming up when powering up. Now the motors dont come ON on teachmode but motors engage in Automode
    I have all safeties jumped
    Images
      • 485.07 kB
      • 1,200 × 1,600
      • 1
    Lemster68
    301
    2,469
    Blog Articles
    7
    • July 29, 2022 at 7:24 PM
    • #28
    You could have a problem with the pendant then. I have to ask if you are pulling in the enabling device to the middle position?
  • Eli
    83
    • July 29, 2022 at 8:21 PM
    • #29
    using one from another working robot and still same issue.
    Lemster68
    301
    2,469
    Blog Articles
    7
    • July 29, 2022 at 8:41 PM
    • #30
    Check for a good connection. Make sure that no pins are bent (not too likely) and for pins pushed in (more likely) on the connector.
  • Eli
    83
    • July 29, 2022 at 9:32 PM
    • #31
    All connections look good, is there something else I'm missing?
    Lemster68
    301
    2,469
    Blog Articles
    7
    • July 29, 2022 at 10:12 PM
    • #32
    Internal connection from the inside panel to main computer for pendant.
  • Eli
    83
    • July 29, 2022 at 11:09 PM
    • #33
    Cables look good and ring the out with fluke
    what about s1.1x1 connection coming from mode switch,does it need jumpers too? It's weird that motors go ON on Auto but not in teach
  • Skooter
    169
    2,026
    • July 30, 2022 at 6:06 AM
    • #34
    Post the actual error number. The term cfg is too generic.
    Could be continuity issue with keyswitch contacts or it could be miswired.
    Double-check continuity of jumpers on DSQC509 Panel Unit.
    Replace Panel Unit
  • Eli
    83
    • July 30, 2022 at 11:24 PM
    • #35
    50242: Unsync due to CFG data
    - Mismatch between controller
    Maybe I didn't explain well as to what I want to accomplish
    Main error facing 50242 , robot and controller have not been used together before
    What I need to know is how to clear previous smb data from controller and add new smb from current arm
    Steps should be similar to irc5 I'm assuming as to using arm with mismatch controller
    -Clear smb data from cabinet
    -adding new smb data from arm
    -calibration
    This is my first time working with s4c plus so I'm confused as to how sbm is cleared and adding new arm
    Any help will be greatly appreciated
