Hello every body
Pls help me I am in an emergency situation
Today after we turned on our robot 2400 abb we found this error on the teach pendant:
from S4C+ user guide
50242: Unsync due to CFG data
- Mismatch between controller
and cfg data for joint %s (calibration
offset or calibration position),
or
- Valid flags for calibration offset
or commutation offset not true in
cfg.
Check:
- Update measurement system:
- Update revolution counter.
- Recalibrate joint.
- Change cfg data.
We have checked all wires and tried to update the revolution counter but we couldn't do it
Then we tried cold start which leads to no change
Right know I am so confused,pls help me to solve it ,thx a lot
ABB2400 error
soorena_79 -
August 30, 2014 at 9:13 PM -
Thread is Resolved
What happend when you update revoluation counter??
Maybe your SMB Unit has some problem if you have another smb unit please check with that and also please check socket of smb because sometimes pins of smb socket has broken -
Thx a lot for or reply
When we try to update it nothings happens and after a warm start we have that same error for all of the motors
Right now we are changing the smb but could u tell me what does the ``change cfg data`` means -
We have changed the smb with a news one which was replaced by a new model:3HAC046277-001
But the error still exist then we changed smb with the one we had on our other robot
So it worked -
We replaced it with the replaced new smb but didn't work then we replaced it with the old one that we took from our other robot then it worked.its surprising ,does the new smb different from the old ones?
What should I do now?even when I buy a new smb I cant use it,
Pls help me I am so confused -
It is really strange actually because I had smb problem with one of my old robot and then I bought new type of smb from ABB then everything was fine. I think you should talk with your local abb, maybe new smb is also broken because new smb must work instead of old type.
Thx a lot for your reply
I think you are right ,now I want to test another new smb board .I will reply about it asap
Thx again. -
Hi
Something strange happened after changing another SMB problem solved,strange is that the first new smb which we bought was already damaged:O -
You are realy unlucky
Yeah and because of that I am on the verge of getting fired
Not sure what controller you have but later controllers require cal offsets to be loaded into the new SMB when it is changed.
Also when you look in the system parameters under the calibration for each motor you should see that the 'valid' flags should be yes. If 'no' you can change it to yes but make sure the cal offsets are correct first.You should call ABB when you fit this new SMB and go discuss the errors as it could be possible the boards are not faulty (faulty boards will generally generate hardware errors not configuration errors).
hello all,
I'm having similar issues with irb 6600 m2000
With mismatch arm. The arm is irb 6600 m2000 irb 6600-175/2.8. I can't find in the menus how ro clear cabinet data /smb and get the new smb from different robot. Controller and arm are same type irb6600 m2000 but with different serial #s
I was able to do calibration after pressing ok once error came up once powered up
and cfg data for joint %s (calibrationbut arm is no engaging motors ON in teach mode/auto
-how can I clear smb data and add new arm smb data?
- if i only need to do calibration as i did why motors dont turn on to jog arm? ( calibration was done as robot came in is not on the calibration marks need to move arm to calibration marks to do permanent calibration once smb issue is resolved error 50242)
Thanks in advance
Eli –
Find the Operating manual IRC5 Integrator's guide (3HAC050940-001) and investigate Chapter 8 Calibration.
Section 8.5 explains SMB memory.
sometekk,
It's a irb6600 m2000 controller (i think controller is s4c but label on controller says irb6600) those options can't be found as in the irc5 controller ..
M2000 = S4C+
How can i update smb for mismatch robot and controller?
I can't find the options in the system
Any ideas as to where options are located to solve this issue
-Update rev.counters
-recalibrate joints
-change cfg data
Did you change out the robot or the controller?
we got it mismatch (buy as is)
