PC Communication with E-Server Function... Not MotoCOM
  • smith_scott
  • August 11, 2014 at 4:43 PM
  • smith_scott
    160
    Has anyone ever tried to implement a PC program using socket communication? I've used MotoCOM many times but I'm wanting to try with sockets now. I'm not very strong with socket programming but I'm wanting to learn.
    I've tried to send the CONNECT Robot_access<CR><LF> command but I do not get response back from the robot.
    Any ideas?
    Any sample code you can share?
    RoboGuru
  • Gamma
    19
    • August 12, 2014 at 11:41 AM
    Hello RoboGuru,
    there is no response expected at this point.
    Here's a docu snippet :
    "Since the Ethernet server function uses the TCP port 80, it can be checked by the telnet command
    from the host computer whether the Ethernet server function operates normally.
    In the Windows2000/XP, the command prompt can be started up to check the connection as
    follows:
    1. Enter "telnet IP address 80".
    2. The display switches to the window for telnet.
    3. Enter "CONNECT Robot_access" (At normal settings, an echo is not returned).
    4. Enter "HOSTCTRL_REQUEST RSTATS 0".
    5. The check is completed when the response to command/answer is displayed.
    C:\>telnet 192.168.255.1 80
    OK: RSTATS
    194,0"
    greetings from Gamma
  • bernietan
    • August 16, 2014 at 2:00 AM
    We have done lots of robot communication using this function.
    I can email you the example code we did. please give me your email address.
  • Ajmal M
    • March 11, 2020 at 10:21 AM
    Quote from bernietan
    I am stuck with socket communication on YRC1000. Can you please give me a detailed step by step instruction on How to do a proper socket communication. I have set all the parameter. Please provide the sample code also. Email: ajmal.ajmal.m@gmail.com
    Thanks in advance!
  • santu
    • July 9, 2023 at 3:39 AM
    我们已经使用此功能进行了大量机器人通信。
    我可以通过电子邮件向您发送我们所做的示例代码。请给我您的电子邮件地址。
    thank u so much!
    853319822@qq.com
    sincerely !
  • apakrat13
    72
    • August 23, 2023 at 5:38 AM
    I learning to use this also. Please send me example if possible. Thank you so much.
    Mail: apakrat18@gmail.com
  • Pho
    • October 30, 2023 at 8:35 AM
    citynguyen18@gmail.com
  • 95devils
    235
    8
    1,951
    • October 30, 2023 at 5:23 PM
    Wouldn’t hold your breathe guys. The user Bernietan hasn’t logged on since April of 2019.
  • SergioJulio
    5
    • December 15, 2023 at 3:54 PM
    Hello bernietan
    I'm trying do the same.
    Can you send this information for me?
    Email: sergiojulio92@gmail.com
  • SergioJulio
    5
    • December 15, 2023 at 4:19 PM
    Quote from smith_scott
    Any ideas?
    RoboGuru
    Hello.
    I'm trying to use this method but something is wrong.
    I used a yaskawa example, like Sample DX 100 just to try connection and then understand how it works, but i cant. Show me an error im message box saying Could not get a handle. Check Hardware key!"
    Anyone hnows what that means and the solution.
