Hello All,
One of my KRC1's consistently fails to load the Kuka software, it doesn't give any error messages. Every time it simply gets hung up on this (see attachment) screen. Any ideas?
Dan
Hello All,
Dan
I'd try replacing the memory as a first job, sometimes it causes this issue.
Sent from my Windows Phone using Tapatalk
Thanks Eusty! I'll give that a shot!
It is related with RAM. You should check or replaced with new one.
Regards,
http://www.robottr.com
Upgraded from 128MB PC133 to 256MB PC133 ...still encountering the freeze issue.
Replace motherboard caps.
I imaged a hard drive from A working KRC1 and now it seems to boot just fine! I think it may have been a software issue. Now that I have a working image on this KRC1 it seems to not be communicating with the hardware (the relays don't engage when you push the large button on the control pendant).
The relay board in this KRC1 is differ from the one I got the image from. Can anyone direct me to a reference as to how to set this up? Or, Can I take the machine.dat files and swap them??
If you have a full Archive from this robot when it was in working order, simply do a Restore All of that Archive. All the unique settings for the robot should be restored. Your original problem was most likely that Windows had developed some fatal file corruption. Copying the hard drive of a working robot fixed that, but now you need to restore the robot's specific settings and programs.
was software version was the faulty robot and what software version is the working one ?
Oooh, yes, good point. I forgot about that little detail.
Both KRC1's are running windows 95.
I found the KRC software versions by running the first prompt of the setup.exe file in D:\KRC1CD\
The functional KRC1 is running -------- KRC V4.1.6 SP3
The non-functional KRC1 is running --- KRC V4.1.4 SP02
Both running late versions then if you restore the archive should work yiy could then run the sp.exe on d drive to upgrade the programmes
But 4.1.6 was not a good a version from memory 4.1.7 SP8 was the final version
Does anyone have a download link for 4.1.7 SP8??? Or do I have to get this from Kuka?
The only legal way to get it is from KUKA.
