Currently I can use 100 position registers. Am I correct this count is limited by setting?
How to configure this limit?
Thanks in advance.
Onno
Thanks in advance.
Onno
go to controlled start and then program setup, I believe you can have 200 max
Thank you very much!
This did the trick.
I remembered the 200 max, but couldn't find the setting.
Best regards,
Onno
is it possible to increase the number of PRs over 200 ?
depending controler you use. With R30iB you can have 300 PR maybe a little bit more but I'm not sure on last part of my answer.
I only know this because I had to look it up this morning myself, but according to the HandlingTool eDoc-"You can increase the number up to 2000(for single group systems)". It doesn't mention a number for multiple group systems though.
in the controlled start menu under menu 0- next 1-program setup
Thanks folks, worked for me! I set it to 200.
R30iB Plus and I can set 373 PR max
This is unique for every controller and the installed software options. Some will have more, some less.
is there any method to increase PR more than 372 , our current r30ib mate plus system has 372
you can go up to 666 with register R830 option
