Hi All
Now i like to use two commands Jump ...If in#....On or Of with Cal job If in#...On or Of.
when i added in to Programed finished and i put buton but it not run . but i test i/o on screen it's have effectived.
that's why ? .
Please help ?
Jump .. If.in#... and Cal...Job If in#...Not to use in ERC ?
anthony -
March 10, 2014 at 5:29 PM -
Could you describe more clearly what you want achieve?
Hi i used that commands to change external stattion box (3 station = in#01-> 1 box ,in#02 -> 2 box, in#-> box 3)
Ex:
Nop
call Job....IF in#01=ON
Call Job...IF in#02=ON
Call Job...IF in#03=ON
END
Nothings any Jobs to run in this program.i don't known why ,may be setting in Paramete ? -
What is turning in#1 ON ? a plc ? a sensor ? switch ?
You can monitor the inputs . Can you see in#1 on and off if you toggle it from the external device ? -
Thanks your reply. I turn on by swicth buton now only use
- wait in#01=ON
- Call Job....
- wai in#02=On
-Cal Job...
-wait in#03=ON
Cal job....
This way not easy .i like Call Job IF= or Jump Job...If=. But I can 't -
Why can't you? Do you not see the IF?
To add the IF construct onto an existing line, complete the following:
1. Press TEACH.
2. Press EDIT.
3. Press Line edit (F4).
4. Press Data add (F3).
5. Press IF comd (F5).
6. Choose conditional type [IN# (F1), IG# (F2), Byte-type (F3), Int-type
(F4), D.Int-type (F5), etc.].
7. Enter the appropriate numerical address for the conditional type chosen.
8. Press ENTER.
Perform only 9.a. for Input, 9.b. for Input Group, or 9.c. for Variable.
9. a. For an Input, choose ON (F3) or OFF (F4);
b. For an Input Group, 1. Choose <> (F4); = (F5).
2. Press Constant (F5).
3. Enter number from keypad and press ENTER.
c. For and B, I, or D Variable, 1. Choose equality/inequality symbol:
> (F2); < (F3); <> (F4); = (F5); or press ( ➤ )
to access > = (F4); < = (F5).
2. Enter value from keypad and press ENTER.
10. Press ENTER to accept the Line edit buffer content.
