VR files
  • jagroop77
  • February 11, 2014 at 6:10 PM
  • jagroop77
    168
    We are system integrators for Fanuc but we sometime get surprised by the fanuc response on certain issues.
    So we want to read and get the information for the SV and VR files.
    Can somebody tell me how to open theses files.
    Is there a software required
    Regards
    Jagroop
  • Racermike123
    14
    901
    • February 11, 2014 at 6:43 PM
    As far as I know you cannot read these types of files.
  • WimJ
    Guest
    • February 11, 2014 at 7:21 PM
    If you connect your PC with your robot controller by ethernet, you can enter the robot server.
    On this server you can see all the SV files and VR files as txt file.
    No special software needed.
  • PFH
    • February 11, 2014 at 10:27 PM
    Hi Rupy,
    You can convert these files with the program KConVars.exe.
    You will find it in your C:\Program Files (x86)\FANUC\WinOLPC\bin when you have Fanuc RoboGuide or WinOlpc installed.
  • Munimula
    40
    • February 13, 2014 at 12:38 AM
    Quote from PFH
    Hi Rupy,
    I tried this. If I double click on the .exe it just flashes a black box for a brief second. Am I missing a step or is my company virus thing killing it. I have had issues with that before.
    &quot;This is one of those industries where the tech level is very high and so are the expectations of our customers(Bosses).&quot; ---&nbsp; RacerMike123<br /><br />R2000ib-165F - R30iA
  • Sergei Troizky
    71
    664
    • February 13, 2014 at 1:02 AM
    Quote from rupy
    Regards
    Jagroop
    Where are the files located?
    In a robot you can access? Or in a robot backup in PC? In the latter case, do you have RoboGuide installed?
  • Munimula
    40
    • February 13, 2014 at 5:16 PM
    i have roboguide installed.
    The KConVars.exe is in the path you mentioned earlier in C/ drive.
    Do I need to open it within roboguide somehow?
    I think I am missing a step but not sure where and as I have 40 other things going on I have no had the time needed to investigate.
  • jay
    25
    82
    • February 14, 2014 at 5:16 AM
    Munimula, KCONVARS requires, at minimum, a file argument. You can also provide several other options:
    Usage: KConvars [/p] infile [outfile][/config inifile]
    Valid file types:
    .sv - System variable file
    .vr - KAREL variable file
    .io - I/O configuration file
    /p - Pause after translating
    /config - Robot configuration file (default robot.ini)
    To select version, use /ver version_id,
    where version_id is an installed version.
    You can do this by either dragging your VR file onto the program (this will presumably create a VA file in the same dir as KCONVARS), or you can use a command prompt.
    ONE Robotics Company
  • Iprogram
    148
    • February 14, 2014 at 12:40 PM
    The VR files and SV files all have a VA file associated with them in the robot that you can view in notepad.
  • leopard
    73
    • February 14, 2014 at 8:26 PM
    To use kconvars to open .sv/vr file, you need to run cmd to open a black window and go to the directory where kconvars.exe is located and copy your .sv/vr files to the same directory. That black window brings you back to the good old DOS days. I open different type register files some times.
    There is another way to see the contents of most contents in those files. Go to system variable screen and press Function then Print. You will get a .ls file on you memory card. Then you can open it with any text file reader. In most cases, this works. But if you are running low on DRAM, the controller will not create that .ls file for you. You can ask the end user to do it and send you the file.
    If you have all the backup files, and you have RoboGuide, you can create a controller with those files. It is almost the same as the real controller.
  • Munimula
    40
    • February 14, 2014 at 11:40 PM
    • #11
    The DOS thing I think I can manage.
    Using the Print function on the select screen doesn't work on the r30ia for .vr or .pc files. It gives a "TPIF-047 Invalid program is selected"
    Edited once, last by Munimula (February 14, 2014 at 11:53 PM).
  • leopard
    73
    • February 16, 2014 at 3:32 AM
    • #12
    Quote from Munimula
    I am not talking about Print in select screen. I am talking about print Variable screen. A lot of contents in .VR and .SV will be printed to the SYSVAR.LS which can be opened by text reader.
  • nithyasri.nm
    Guest
    • November 10, 2017 at 8:41 AM
    • #13
    I have a back-up of a paint robot in my PC. I want to view the mastering values of that robot.
    I tried to read the values using kconvars.exe application.
    But still I was not able to view SYSMAST.SV file and get the mastering values from the back-up
    Can someone help me?
