Hi,,i now working on kuka krc1 robot that comissioned in 2005,, but for some reasons robot turned off,,know we decide to operate it again,, when we turned on the robot drive teach pendant dont display any thing but operation mode selector swicth has effect on driver,we changed the kcp but problem not solved,
please help me in this case
KCP KR1 don't display any thing
dhassanlou -
February 5, 2014 at 5:29 PM -
Check the motherboard and look to see if any of the capacitors are domed.
This is the first thing I'd check on a KRC1 having replaced so many motherboards!
Sent with Tapatalk.
If it's not the motherboard, there is lot of chance that inverter part of KCP is hs !
Maybe KCP background light is defect.
thanks a lot ,,
i replaced motherboard with new one .. problem solved ,, now i want repair motherboard,, when i checked ,, some of capacitors has been defected ,, maybe bye change the capacitors i can use that again,,
again ,,,thanks,, -
replace all the caps and you can use it again no problems
