fanuc R30iA to generate DO when robot is in step mode in auto mode
  • Roboter
  • December 13, 2013 at 8:17 AM
  • Roboter
    51
    I want fanuc R30iA to generate DO( for alarm) when robot is in step mode in auto mode.
    I have used variable $EXT_DI_STEP = TRUE, $DO_NUM = 288 ; It works fine in T1 & T2 mode but in auto mode step mode didn't work at all.
    After cold start also it is not working in auto mode.
    PMC function is enabled in this robot.
    :help:
  • Sergei Troizky
    70
    658
    • December 15, 2013 at 6:20 PM
    BG Logic DO[n]=($SSR.$SINGLESTEP)
  • Roboter
    51
    • December 15, 2013 at 7:00 PM
    Thanks san,
    I have tried it earlier also but it didn't seem to be working. In BG Logic it is showing " stop " even after cold start. Moreover Iam not able to use step mode in auto mode. Should I only use BG logic and disabling the variable $EXT-DI-STEP...
    :help:
    Nation
    Typical Robot Error
    542
    1,924
    • December 16, 2013 at 6:02 AM
    You have to tell a BG program to start, which I think is the F3 key in the BG menu under setup.
    Another solution is that you can use the Enable UOP output to monitor step mode. It will go low when the robot is in step.
  • Roboter
    51
    • December 16, 2013 at 6:12 PM
    Thanks to all for help & support...
    I have used only BG logic.
    DO(N)=$SSR.$SINGLESTEP
    But what about variable $EXT_DI_STEP ??? Is there any significance of this variable...
  • Bagrant
    15
    • December 17, 2013 at 3:54 PM
    "But what about variable $EXT_DI_STEP ??? Is there any significance of this variable..."
    anand kesari:
    I believe any variable $EXT is associated with Extended axes. Your not concerned with an axis 7,8,9,etc. being in step mode are you?
  • SEAN-DUDE
    65
    • December 17, 2013 at 8:51 PM
    What i have done at my shop is create a program that runs in background on hot and cold start, which is under system config
