I messed up and changed the IP address on my KRC4 and now the smart pad wont connect . I set the address on the KRC4 back to OEM, but the smart pad still won't connect.
Smart pad IP Adderss
Robotech -
November 4, 2013 at 7:36 PM -
Have you unplugged and then plugged it back in?
It receives its IP address from the cabinet via DHCP
Sent using Tapatalk 4
I have. when i translate the error message i get "IP Address can not be set error when the automatic IP address"
why don't you post message exactly as it appears?
Here is photo of the smart pad
I set the address on the KRC4 back to OEM, but the smart pad still won't connect. ?
Have you got an external monitor then ? has the krc booted up
Have you tried RDP on the smart pad
turn key
press Kuka button
select rdp then connect ? -
Have you still got the monitor connected? You can't connect both at the same time as the controller has to have a SPOC.
Have you still got the monitor connected? You can't connect both at the same time as the controller has to have a SPOC.Sent using Tapatalk 4
I got it going again. I had to stop the KRC and start it back up.
