Ok guys, I'm almost done, spindle mounted and spin tested, now I need to find a way to let the robot know that the stock is 1200mm away to right (right side of the robot), I know I can input 1200mm at the 7th axis in RM(Robotmaster) but I haven't got the right post yet, so I need find an alternative way to move E1 1200mm to the right. I have tried moving E1 (Linear Axis) 1200mm to the right by jogging it, but when I execute a program it returns to the position in the 1st place, would it work if I move the robot to he right then turn off E1 in machine data?
Almost reay for Milling!
happytriger2000 -
August 25, 2013 at 10:25 AM -
Thread is Resolved
Just modify the .E1 component of your move in the program.
Sent using Tapatalk 4
Did a little bit of searching, I need to add PTP{E1180} somewhere in the program, right?
But that is in degree, how about in linear distance 1220mm? -
It depends on how your external axis is set up, but if it's a track then generally the E1 value is in mm.
Yours looks like it's a Kuka track so there should be no issues.
PTP{E1 1200.0}
It depends on which points in your program include an E1 value. If every point includes a value for E1, then you'll need to make the correction to every point. If only one point includes an E1 value, then you only need to correct that one.
I moved the base/stock closer to the robot+track and the Base co-ordinates becomes:
x=1510
Y=16.5
Z=484
A=0
B=0
C=0
this also reduce the "Red lines" when calculating tool orientation where as before I often get "Out-of-Reach"
No PTP E1 -1200 is used. -
Ok, started facing the PU block!!
http://youtu.be/Nt4JfJIkaq0 -
What do you want to mill? I made one demon head about a week ago
if you like it, can do the code?
take a look: -
wow, that's a nice 3D model, did you you create that?
I want to try this:
http://youtu.be/AHduM9odoJk -
Yes - it is my model... i can add a torso if you want. Or can do a bust -
Not sure how to do the rotational axis, but will give it a try -
Is it Maya, 3Dmax, Freeform + sensable? It looks really high def., I like it. Is not a 3d scanned model is it? how long did it took you to create the head in CAD?
I can try milling the head, but 1st need to do the 8th axis rotation sync with 6 axis like in the video. -
It is done in Zbrush - i am learning it. Took me about four hours to do it - still not complete.
I can try to do this for you in Sprutcam?
if you can send my a file of the demon cad i can try it also with Delcam Powermill Robot Interface.
Vvelikov,
Sprutcam is fine, but do you have the post for external axis?
Potis,
have uoi tried the rotation method before?, maybe you can give it a try. -
Hmmm...I'd be careful with that demon head. I think there is a high risk for collision due to the many holes and blind spots. Also the tips of the horns might not withstand the vibrations. You will probably need a true maestry with conv/climb, speeds and tool direction.
I will soon post you pics and facts from some of our CAD-to-Robot solutions. We have achieved Robot, Robot+1 ext. axis and Robot+2 ext.axis operations for milling, cutting, welding and dispensing projects. Solidworks, UG, Powermill and/or customised prc for KUKA, Motoman, Fanuc and Mitsubishi. Unfortunately, most of the customers do not allow any info to go public due to the major step-ahead that they maintain at the moment. As soon as their products hit the market, we are free to gradually release info, so please allow me some time.
Potis: here is the file:
I am not sure what is the real size of the Head (it should be about 300mm in height), so check it in your software and change it if needed.
RAS-Skordos GR:
I would do a model like this one in separate pieces... but for the testing it is not needed to do it with that level of detail may be.
I am attaching the last model i did in MDF -
happytriger2000: to do the code for you i will need to know more about your tooling - what size router bit you have/want to use for this foam and also some info about the tool holder to prevent it touching the part.
The cutter bit is: 20mm dia. 256mm length.(from tool tip to tool holder), tool holder HSK F63.
