Hi I'm here again
I must change a toothed belt of ax5 there is a manual how to change it?
toothed belt
axv6l -
April 25, 2012 at 7:43 AM -
You should change both belts at the same time and you will need a frequency meter to do it
It is quite easy to do -
I must change a toothed belt of ax5 there is a manual how to change it?The manual would be the maintenance manual but there is at least one per robot model. What robot model is this for?
kuka kr15
Why must i change the belts in the same time only belt of ax5 is broken
A few months ago we replaced the wrist belts on my KR60HA robots. The belts from Kuka were cheap, $43 each, so for that price you might as well just change both, They are supposed to be changed every two years anyways, if I remember correctly. It concerns me that you have a broken belt, how many years old are the belts in the robot?
However, the frequency measuring device from Kuka was not cheap, PN 71-053-386 about $3800. I don't know why it's so expensive.
Best to change them both as they will have the same wear and only takes 5 mins more to do both but it's up to you
Sent from my Nexus 5 using Tapatalk
