I need to disassemble the teach pendant KCP2. Does anyone have some manual or advices how to ?
Thank you very much !!!
J.M.
How to disassemble the teach pendant KCP 2 std. ed 5
jirikk -
June 1, 2011 at 5:24 PM -
Wish I had a couple photos to post . That would make I easier. It's not too hard. I've had to replace a few cables and maybe a switch..Any way there are 8 Phillips head screws to remove one is under a plastic plug that I believe voided a warranty on the pendant. I've actually removed it successfully with a very small control screwdriver. There are two more under the plastic guard that surrounds the drives on off buttons all on the backside. After that there are plastic tabs around the edge of the shell halves. Pop them in with the screwdriver and separate the two halves. The cable is anchored by two straps screwed in to one half. Then the cable plugs into a connector. Reverse order to put it back together.
i have video and pictures for repair KCP(2), I could send for you
send me e-mail i send more pictures and video
Just a note
If you return it KUKA chances are they will not accept it as exchange once it has been opened
HI and thanks a lot to for advices !!!
Finally I had to send the TP to kuka to change some part, but it was not expensive.
J. -
How many cost the exchange TP with KUKA? under or more 1500usd. Are you received your part under time?
i haven't exchange all TP, only something inside, it cost around 900 CAD. but to exchange TP for new one... no idea, but I think more then 1500$. Since this repair was not urgent, I did not push them to repair it ASAP. -
Im trying to open a KCP2. Any tips on taking off the 3d mouse?
