Hello, help me correctly add the start and end welding (Arcon and Arcoff) commands, without a trigger. What minimum parameters must be specified for the welding process to work?
Example:
LIN xP1 : start of welding
LIN xP2 : end of welding
Example:
Depends on your welder. I've had Lincoln welders have a "Touch sense" routine to manage stick-out before you arc on.
I'd personally consult your welders manual to see if they suggest or have access to different things like Stick-out or "start Arc" functions. See if those are mapped in what ever I/O structure you're using.
