Arctech welding in external axis
  • Faris Nafiah
  • November 27, 2023 at 1:29 PM
  • Faris Nafiah
    Hi all,
    Robot KR20 R1810
    Controller KRC4
    External axis/positioner KP2 HV2600HW
    ArcTech Basic 3.0
    I have a tube, placed on the positioner (KP2 HV2600HW), and what I would like to do is to position the welding torch perpendicularly to the length of the tube, start the arc, rotate the turntable 90 degree in E2 using LIN, and arc off. This works fine, except that I cannot control the velocity of the turntable rotation by setting the ArTech's robot velocity parameter. It seems the "robot velocity parameter" only applies to the KR20 robot path.
    The structure of the program is as follows
    PTP Home
    ArcOn Lin (position the welding torch perpendicularly to the tube)
    ArcOff Lin (rotate the turntable, without moving the welding torch)
    Is there a way to do execute ArcOFF with static welding torch?
    Kind regards
    Faris
  • Lemster68 November 27, 2023 at 2:04 PM
    Approved the thread.
  • sloopkogel
    34
    • January 31, 2024 at 9:31 PM
    i have recently done something similar. See my topic: Welding with Arctech and simulated external axis
    In a nutshell you need to:
    - calibrate and synchronise a base with your external axis
    - you need to use circ movement instead of lin
Similar Threads
  • Welding with Arctech and simulated external axis
    • sloopkogel
    • August 2, 2023 at 1:11 PM
    • KUKA Robot Forum
  • Disabling robot movement check during active welding
    • filonovsy92
    • July 1, 2022 at 4:14 PM
    • KUKA Robot Forum
  • KUKA roboTeam
    • Rainman
    • June 19, 2022 at 8:59 PM
    • KUKA Robot Forum
  • weave delay not working on slave robot while it following the external axis (linear unit)
    • Thunder
    • April 8, 2022 at 5:22 AM
    • KUKA Robot Forum
  • ArcTech
  • External axes
