  4. ABB Robot Forum
ABB welding robot relocating.
  • Aurelijus Pr.
  • April 15, 2024 at 7:50 PM
  • Aurelijus Pr.
    8
    What actions will need to be taken when relocating an ABB welding robot with positioner ? Will all the programs created before the relocation work.
    Thanks.
  • Lemster68 April 15, 2024 at 7:55 PM
    Approved the thread.
  • Lemster68
    299
    2,466
    Blog Articles
    7
    • April 15, 2024 at 7:58 PM
    Regardless of the kind of positioner, (which still would be nice of you to mention) take careful measurement of where they are in relation to one another. You could even teach the robot some points to verify that they are replaced in a repeated relation. Take backups. Label anything that must be disconnected if it is not already labeled. Take lots of pictures.
  • Aurelijus Pr.
    8
    • April 15, 2024 at 8:25 PM
    Positioner IRBP A. Robot IRB 1600.The robot will stand at a 45-degree angle in the new location. I think that the old programs will no longer work. Is it possible to make the old programs work in the new location..
  • Viperacebb
    5
    26
    • April 15, 2024 at 9:35 PM
    Like Lemster68 has said, measure everything accurately and even make a routine for the robot to go to known points (edge 1, edge 2, edge 3) and move the positioner back to those positions taught versus where they were. You may still need to touch up a little bit, but hopefully not. Label and take a ton of pictures (they help more than you expect). If you could build a template out of wood as to the base of the robot to the base of the positioner, this may work very well too. Best of luck!
  • Skooter
    169
    2,021
    • April 16, 2024 at 12:12 AM
    Do the positions in your program reference a Work Object and if they do is it something other than Wobj=0?
  • Aurelijus Pr.
    8
    • April 16, 2024 at 6:56 PM
    Quote from Skooter
    Yes, all detail templates have their own work objects. Not wobj0.
  • Aurelijus Pr.
    8
    • April 16, 2024 at 6:59 PM
    Quote from Viperacebb
    The position of the robot and the positioner at another location will be different from the initial position.I don't know what will happen with the old programs. The robot will change its position by 180 degrees around its axis. the position of the positioner remains the same.
  • Viperacebb
    5
    26
    • April 16, 2024 at 8:19 PM
    At this point, I would make sure that all the positions are using a work object for the weld area. Was it taught with a work object? Is there an extension after the tool (:\wobj_fixture; or something like this)?
  • Lemster68
    299
    2,466
    Blog Articles
    7
    • April 16, 2024 at 8:51 PM
    May I ask why the robot is being rotated 180 degrees on relocation?
  • Aurelijus Pr.
    8
    • April 16, 2024 at 9:15 PM
    Quote from Lemster68
    The position changes from right to left
  • Lemster68
    299
    2,466
    Blog Articles
    7
    • April 16, 2024 at 9:58 PM
    • #11
    Not how but WHY?
  • Aurelijus Pr.
    8
    • April 17, 2024 at 7:45 PM
    • #12
    Not how but WHY?
    Because there is no possibility to build in the place where it will stand according to the layout of the old place.
  • Aurelijus Pr.
    8
    • April 17, 2024 at 7:47 PM
    • #13
    Our factory is being reconstructed, therefore the robot cell is being reformed.
  • Lemster68
    299
    2,466
    Blog Articles
    7
    • April 17, 2024 at 8:50 PM
    • #14
    In this case, we could think of it as another robot and mirror the programs.
  • MathewWallbank
    21
    • May 19, 2024 at 12:33 AM
    • #15
    Theres a python program that converts inverse pose data like this. Also to convert posistion data to a new wobj. Not a perfect system though.
    Setting up programs with useful wobj reference would help for things like this.
    The irc has a mirror program and mirror routine function in the controller. It will mirror the program across a plane you define with 3 programmed points, as described in the manual. It might not be appropriate for the positions of your weldment though. Count on touching up a lot of points
    Super jelly of that positioner. Those are nice units.
    Mw:bell_pepper:
