I am configuring my first robot, from start all by myself. I used to work on KUKA robots before but all projects and configurations were already made there.
I am using KUKA Agilus KR 10 R1100 with KR C5 micro controller, dont know what KSS version.
I tried to connect robot to my laptop and upload current project into WorkVisual. Ive seen that in the project current IP adress is 172.31.1.147, Ive set ip adress on my laptop to be in the same network but I could reach robot still. I tried few more things and finally went to system settings on the teachpendant to change the ip in the network settings there. I've put the same IP adress there as was in the project configuration (172.31.1.147) and lost connection with my teachpendant. I assume that there is now an adress conflict. After reseting the controller I can no longer connect my teachpendant to correct the ip adress there.
Any suggestions what should I do to solve it?
Thanks in advance
