Negative value from PLC
  • LUCAF
  • March 29, 2024 at 11:26 AM
  • LUCAF
    Hi everyone, I'm trying to transfer a 16-bit signed integer from an API.
    code : SIGNAL offset_x $IN[124] TO $IN[139]
    on the plc side, my variable is declared as a signed integer
    when I visualise my variable "offset_x" when I send 25 I receive 25 but when I send -25 I receive 65511 which means that on the work visual side my variable is declared as a UINT
    Can you help me solve my little problem?
    Thank you
    Translated with DeepL.com (free version)
  • Fubini March 29, 2024 at 11:42 AM
    Approved the thread.
  • MOM
    175
    7
    1,424
    • March 29, 2024 at 1:52 PM
    This is correct.
    For negative number the "Two's complement" is used
    The explanation can be found here
    65511= '1111 1111 1110 0111'
    MSB (red) = 1 => number is negative
    If we would just take 8 bits then the number would be 231 in binary '1110 0111'
    -128+64+32+4+2+1 = -25
  • hermann
    407
    2,612
    • March 29, 2024 at 2:45 PM
    Easiest way is to expand the signal to 32 bit. Then the Kuka uses the MSB as sign automatically.
    Otherwise you have to caculate the two's complement by yourself
    value = offset_x
    if value > 32767 then
     value = value-65536
    endif
Similar Threads
  • Group Inputs/Group Outputs between RobotStudio and Allen-Bradley PLC
    • PhilC
    • September 13, 2023 at 9:38 PM
    • ABB Robot Forum
  • Send a real number to PLC (siemens) connected by Profinet
    • MoEL
    • September 7, 2023 at 4:14 PM
    • Fanuc Robot Forum
  • Get signed 32-bit integer from two unsigned 16-bit GI's
    • hoitzing
    • February 28, 2023 at 10:39 AM
    • Fanuc Robot Forum
  • Negative Data Pass
    • Chris
    • June 6, 2016 at 3:43 AM
    • Fanuc Robot Forum
  • sps.sub user PLC section
    • robot-cnc
    • December 29, 2022 at 1:54 PM
    • KUKA Robot Forum
  • Have You Ever Crashed A Robot?
    • ablant527
    • June 14, 2021 at 9:31 PM
    • General Discussion of Industrial Robots Only
  • Connecting Kuka Arm to Arduino using Media Flange
    • Pt13
    • March 31, 2022 at 7:13 PM
    • KUKA LBR IIWA
  • Passing positions to siemens PLC over profibus
    • jariuscs
    • April 23, 2020 at 6:19 PM
    • Fanuc Robot Forum
  • négatif
  • valeur
  • entier
  • signé
